Broke the trans again #1437795
05/16/13 11:53 PM
05/16/13 11:53 PM
Great Neck,LI,new york
hemi-itis Offline OP
Went for a ride Tuesday night and had the chance to try WOT on a nice 2 lane concrete highway.At the top of 2nd just when I clicked high gear I heard and felt a major BOOM under my feet .Clicked the key off and watched out the rearview mirror expecting see all kinda parts trailing me.Rolled to the side of the road and looked under the car to see everything in place and nothing leaking so I restarted the engine and went through the gears,but nothing happened
After I got a ride to get my flatbed,towed it back to my shop,put it up on jackstands and pulled the pan to find NOTHING but clean fluid
Pulled the unit out last night and called it a day.Went and pulled the trans apart today and found a broken retainer hub on the back of the input shaft.
I see a new heavy duty maybe billit replacement in my future.
Who should I get a new one from?TCS,Cope,,,,,or???
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Broke the trans again [Re: hemi-itis] #1437796
05/16/13 11:55 PM
05/16/13 11:55 PM
Re: Broke the trans again [Re: hemi-itis] #1437797
05/17/13 12:58 AM
05/17/13 12:58 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
TCS sells some nice input shafts that are bigger diameter at the hub end.
Mopar to the bone!!!
Re: Broke the trans again [Re: 72Swinger] #1437798
05/17/13 08:56 AM
05/17/13 08:56 AM
I broke the same part about about9 years ago when I tried srayin outta the hole.I shoulda bought the good part then
Re: Broke the trans again [Re: hemi-itis] #1437799
05/17/13 09:05 AM
05/17/13 09:05 AM
gregsdart Offline
gregsdart  Offline
ouch! The good news is yer makin some torque! Its great when that BOOM is only going to cost hundreds! Vs thousands!
Re: Broke the trans again [Re: hemi-itis] #1437800
05/17/13 02:46 PM
05/17/13 02:46 PM
NC
440Jim Offline
440Jim  Offline
NC
I have seen them break when machined too much to fit a torrington bearing into them. On my 727, I only cleaned up the area for the torrington and took material off the front drum to make up for the axial distance change.
But they do make a stronger aftermarket part too.
Re: Broke the trans again [Re: 440Jim] #1437801
05/17/13 02:54 PM
05/17/13 02:54 PM
Florida STAYcation
dOOc Offline
The village idiot's idiot
dOOc  Offline
Florida STAYcation
'itis ... it is that heavy shifter and all those gauges that is weighing-the-car-down and putting strain on the drivetrain ...
Re: Broke the trans again [Re: hemi-itis] #1437802
05/17/13 02:56 PM
05/17/13 02:56 PM
I'm really glad it broke the way it did and didn't hurt you Instead of exploding like a hand grenade It is thin where it failed
Re: Broke the trans again [Re: hemi-itis] #1437803
05/17/13 03:02 PM
05/17/13 03:02 PM
Staten Island N.Y.
Dap Offline
Dap  Offline
Staten Island N.Y.
When I had mine apart the last time I found six cracks in mine. Time for an upgrade while you are there.
PRH446
10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
Re: Broke the trans again [Re: hemi-itis] #1437804
05/17/13 05:21 PM
05/17/13 05:21 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You should probably replace anything that is available billet now and be done with it . I'm sure you know you are only going to keep finding the weakest links as you go .
What parts are in it now , Drum ? Sprag ? Pump gears ? front Planet ? Output shaft ?
Re: Broke the trans again [Re: JohnRR] #1437805
05/17/13 08:41 PM
05/17/13 08:41 PM
Kokomo, IN
540dust Offline
540dust  Offline
Kokomo, IN
This came out of a customer's trans, suspected/witnessed that the brake was set while cruising in the pits, maybe a couple of times, so it could have experienced some "impacts". Odd thing is when it broke it was in 4th round eliminations running me. Anyway, they brake there.
Re: Broke the trans again [Re: 72Swinger] #1437806
05/17/13 10:11 PM
05/17/13 10:11 PM
I got their billet fron drum so I went back to them for the shaft & hub http://www.tcsproducts.com/products/product/17/
Will have new parts on Tuesday and will go to Tom's house and have him take care of it
Re: Broke the trans again [Re: gregsdart] #1437807
05/17/13 10:13 PM
05/17/13 10:13 PM
LMOL. You got that right Greg
Re: Broke the trans again [Re: 540dust] #1437808
05/17/13 10:16 PM
05/17/13 10:16 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I have never had enough power to do the damage I am seeing here. I have broken extension housings and blown the servos out of the case due to bad or badly installed snap rings. It seems to me you might be wise to invest in either a PG or a TH400 with an Ultrabell. There has to be a point where it just makes sense to change, but I don't know where that is.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Broke the trans again [Re: dOOc] #1437809
05/17/13 10:16 PM
05/17/13 10:16 PM
I have that lightweight plutonium/unobtainium shifter material that was scientificly balanced.
I should be in the Keys for that race
Re: Broke the trans again [Re: JohnRR] #1437810
05/17/13 10:21 PM
05/17/13 10:21 PM
Just ordered the pump gears http://www.tcsproducts.com/products/product/478/
My builder is confident I won't break the stock output
Have the drum,sprag,A&A planets but no brake.I'll stick to footbraken
Re: Broke the trans again [Re: Cab_Burge] #1437811
05/17/13 10:23 PM
05/17/13 10:23 PM
I'm happy it happened in the street and not after I hauled everything and everybody to the track.Maybe next week
Re: Broke the trans again [Re: Polarapete] #1437812
05/17/13 10:25 PM
05/17/13 10:25 PM
I'm way past that point.You'll never see a GM trans in my mopar,I won't give up my pushbutton shifter!!
Re: Broke the trans again [Re: hemi-itis] #1437813
05/17/13 10:29 PM
05/17/13 10:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats been cracked for a while... shouldnt blow that
going into high(less torque at that point) plus it has
some shine and smooth edges.... JMO
Re: Broke the trans again [Re: hemi-itis] #1437814
05/17/13 10:35 PM
05/17/13 10:35 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Maybe it's time for a change
64 Plymouth Savoy
Dana 60
