Maximum compression with a hemi on E-85??
#140815
10/24/08 10:03 AM
10/24/08 10:03 AM
Posts: 7,497 Minnesota
Hemi_Joel
Minnesota
What would be the most compression a guy could run on E85 with out haveing to make compromises like retarding the timing? this would be a 4000 pound street car with 3.54 or 3.73 gears with a Passon 20% overdrive gear in the 4 speed. Specs on the motor:
484 Hemi 4.310 bore x 4.15 stroke ported iron heads hydraulic roller cam 226/230 at 542 lift 112 lobe centers Inline street Hemi intake with AFBs exhaust manifolds and 2.5" exhaust
Thanks, Joel
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: Maximum compression with a hemi on E-85??
[Re: quickd100]
#140822
10/24/08 08:51 PM
10/24/08 08:51 PM
Hemi_Joel
Minnesota
Thanks Dave. I think I have most of the parts on hand to assemble a 12.8 to 1 motor. I didn't know if I should use a thicker head gasket to drop the squeeze down a bit. Sounds like I should put it together at 12.8.
[Re: Hemi_Joel]
#140824
10/27/08 07:10 AM
10/27/08 07:10 AM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
I learned a lot from the info at www.E85forum.com. Lots of good stuff there to help make the right decissions.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
