Maximum compression with a hemi on E-85?? #140815
10/24/08 10:03 AM
10/24/08 10:03 AM
Minnesota
Hemi_Joel Offline OP
Minnesota
What would be the most compression a guy could run on E85 with out haveing to make compromises like retarding the timing? this would be a 4000 pound street car with 3.54 or 3.73 gears with a Passon 20% overdrive gear in the 4 speed. Specs on the motor:
484 Hemi 4.310 bore x 4.15 stroke
ported iron heads
hydraulic roller cam 226/230 at 542 lift 112 lobe centers
Inline street Hemi intake with AFBs
exhaust manifolds and 2.5" exhaust
Thanks, Joel
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Maximum compression with a hemi on E-85?? [Re: Hemi_Joel] #140816
10/24/08 10:14 AM
10/24/08 10:14 AM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Back when I did my conversion, the research that I did showed that 15:1 was very doable. My 11:1 was considered to be on the low side to take advantage of the octane rating of E-85. My first time down the track with E-85 was within .1 of my very best time on pump gas with no timing change.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Maximum compression with a hemi on E-85?? [Re: 68LAR] #140817
10/24/08 05:09 PM
10/24/08 05:09 PM
North Carolina, USA
Silverbullet2 Offline
North Carolina, USA
What is the octane rating for E85? Did you have to rejet for it?
Re: Maximum compression with a hemi on E-85?? [Re: 68LAR] #140818
10/24/08 05:10 PM
10/24/08 05:10 PM
Minnesota
Minnesota
WOw, 15 to one is really up there. I don't think I want to go that high. What is the octane rating of E-85
THanks,Joel
Re: Maximum compression with a hemi on E-85?? [Re: Hemi_Joel] #140819
10/24/08 05:14 PM
10/24/08 05:14 PM
Fischer, TX
dodgepu360 Offline
dodgepu360  Offline
Fischer, TX
where can I find more info about converting an old carburated engine over to E-85?
a quick search of the board only turned up this thread
thanks
Re: Maximum compression with a hemi on E-85?? [Re: dodgepu360] #140820
10/24/08 05:56 PM
10/24/08 05:56 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
thanks
Mabe when you do a search you should just put
E85
And make the search for one year as I think default is 1 week. There is a ton if you are willing to do a search. Also google E85 forum, as well as E85 conversion.
https://board.moparts.org/ubbthreads/showthreaded.php?Cat=0&Number=4765041&page=0&vc=1
I think one of the members in the race section has 16:1 with E85
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Maximum compression with a hemi on E-85?? [Re: HealthServices] #140821
10/24/08 06:05 PM
10/24/08 06:05 PM
nielsville, minn.
Q
quickd100 Online content
quickd100  Online Content
Q
nielsville, minn.
I know 15.9-1 has been sucessfully done in a 654ci hemi on E-85. Joel I wouldn't be a bit afraid to try 12.5-13.5-1.
E-85 is rated at 105 octane but has different burn characteristics than gasoline. You also get the cooling effect than alcohol provides. When I ran it in my 440 right after startup, often times my intake manifold would be sweating. Operating temps were about 15-20 degrees cooler than on gasoline. Dave
Re: Maximum compression with a hemi on E-85?? [Re: quickd100] #140822
10/24/08 08:51 PM
10/24/08 08:51 PM
Minnesota
Minnesota
Thanks Dave. I think I have most of the parts on hand to assemble a 12.8 to 1 motor. I didn't know if I should use a thicker head gasket to drop the squeeze down a bit. Sounds like I should put it together at 12.8.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Maximum compression with a hemi on E-85?? [Re: Hemi_Joel] #140823
10/26/08 12:32 PM
10/26/08 12:32 PM
dogdays Offline
dogdays  Offline
I believe one of the magazines supercharged a 13:1 big block chevy on E-85 and it didn't have detonation problems.
R.
Re: Maximum compression with a hemi on E-85?? [Re: Hemi_Joel] #140824
10/27/08 07:10 AM
10/27/08 07:10 AM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
I learned a lot from the info at www.E85forum.com. Lots of good stuff there to help make the right decissions.
