What would be the most compression a guy could run on E85 with out haveing to make compromises like retarding the timing? this would be a 4000 pound street car with 3.54 or 3.73 gears with a Passon 20% overdrive gear in the 4 speed. Specs on the motor:
484 Hemi 4.310 bore x 4.15 stroke
ported iron heads
hydraulic roller cam 226/230 at 542 lift 112 lobe centers
Inline street Hemi intake with AFBs
exhaust manifolds and 2.5" exhaust
Thanks, Joel
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
I don't regret the things I've done. I only regret the things I didn't do.
"Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
