Page 3 of 4 1 2 3 4
Re: 71 Charger at Hotchkis for R&D [Re: dangina] #1356244
01/03/13 08:37 PM
01/03/13 08:37 PM
Santa Fe Springs, CA
Dan@Hotchkis Offline OP
my frame needed the same spot fixed as well, i wonder what caused it
There is a piece of boxing that is put in by the factory. It blocks off the channel and is a great place for crap to build up and store moisture.
Re: 71 Charger at Hotchkis for R&D [Re: Dan@Hotchkis] #1356245
01/03/13 09:27 PM
01/03/13 09:27 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Wow. Good catch!
For reference/education, can you post a picture of that area a little farther back, so I can better tell where it is at? Also, do you have a photo of the frame with that section removed?
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: 71 Charger at Hotchkis for R&D [Re: DynoDave] #1356246
01/03/13 09:50 PM
01/03/13 09:50 PM
Sure. I'll snap a picture tomorrow. It's pretty easy to find because of the spot weld divots in the frame.
Re: 71 Charger at Hotchkis for R&D [Re: dangina] #1356247
01/03/13 11:16 PM
01/03/13 11:16 PM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
In that pattern and location i'd guess it is corrosion weakened metal coupled with frame flex. Ended up completely failing/fracturing thru at the small fissures that originally developed.
Re: 71 Charger at Hotchkis for R&D [Re: Dan@Hotchkis] #1356248
01/04/13 10:46 PM
01/04/13 10:46 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Thank you sir!
DynoDave
Member # 12304
Re: 71 Charger at Hotchkis for R&D [Re: DynoDave] #1356249
01/04/13 11:14 PM
01/04/13 11:14 PM
Here is a pretty good picture of what is left of that "block". There was a lot of debris in the rail when I cut it open.
And the finished repair. With the varying thickness of metal to weld to, this was quite a project.
Re: 71 Charger at Hotchkis for R&D [Re: Dan@Hotchkis] #1356250
01/05/13 12:34 PM
01/05/13 12:34 PM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
same spot on my car just slightly more towards te front of the car - repair looks good
Re: 71 Charger at Hotchkis for R&D [Re: Dan@Hotchkis] #1356251
01/05/13 12:52 PM
01/05/13 12:52 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
See if you can get ahold of some of the body cavity wax/rust protection products to spray in through a hole and stop the rest from rusting out. These use a long wand that will get in and spray all over so it will all get coated. Look in Eastwood. But do it after the welding as it will contaminate the welding process.
Carl Kessel
Re: 71 Charger at Hotchkis for R&D [Re: CKessel] #1356252
01/05/13 06:55 PM
01/05/13 06:55 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Interesting. A lot more layers of metal...a lot more going on...inside that rail than I knew of. Thanks for sharing this Dan. And congrats on a nice looking repair.
DynoDave
Member # 12304
Re: 71 Charger at Hotchkis for R&D [Re: DynoDave] #1356253
01/22/13 09:36 PM
01/22/13 09:36 PM
Well, just finished up the Sub frame connectors, and they look great! The second set will be mailed out tomorrow so the jig can be built. waiting on production to give me another front sway bar and we will be in business.
Been waiting forever for some brake hardware and the new radiator, that finally came in today, so as soon as I get the brakes plumbed up tomorrow, we should be ready to drop the body back down on the engine and suspension!
Re: 71 Charger at Hotchkis for R&D [Re: Dan@Hotchkis] #1356254
01/23/13 12:34 AM
01/23/13 12:34 AM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
How about some pictures of those parts on the Charger?
Re: 71 Charger at Hotchkis for R&D [Re: PHJ426] #1356255
01/23/13 10:51 AM
01/23/13 10:51 AM
TOP SECRET!
Re: 71 Charger at Hotchkis for R&D [Re: Dan@Hotchkis] #1356256
01/23/13 01:25 PM
01/23/13 01:25 PM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
I thought you wanted to sell some parts?
Why the top secret or is there something Im not picking up since we are just typing and not face to face?
Or do you mean there will be no pictures until the product is released for consumers to purchase????
Please clarify.
Re: 71 Charger at Hotchkis for R&D [Re: PHJ426] #1356257
01/23/13 05:44 PM
01/23/13 05:44 PM
Once we have a final product to sell to customers or the boss gives me the okay to leak pictures, I can't leak images of R&D phase items.
Re: 71 Charger at Hotchkis for R&D [Re: Dan@Hotchkis] #1356258
01/24/13 12:02 AM
01/24/13 12:02 AM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
Fair enough....Ill be waiting to see what you guys have available when it hits the shelves.
Any idea when they might be stamped for approval?
Re: 71 Charger at Hotchkis for R&D [Re: PHJ426] #1356259
01/24/13 01:53 AM
01/24/13 01:53 AM
I was supposed to ship the prototypes to HQ to have the jiggs built today, however the car we got for R&D isn't very square. I'll be test fitting the prototypes on another 72 Charger within the week. After that they have to be shipped to HQ, jigg built and then the first run can be made. I'd say 30-45 days to be safe.
Re: 71 Charger at Hotchkis for R&D [Re: Dan@Hotchkis] #1356260
01/24/13 02:14 AM
01/24/13 02:14 AM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
How far off is the car from side to side?
Would that show up on a 4 wheel alignment rack as well?
Since you found out since your building subframe bars for the car and you seen a discrepancy in the two sides?
We found my car had 2 different length front spring hangars on a 4 wheel alignment. Got that fixed and all was good. This was when I first bought it. Spin the tires and then let off the throttle the back end would snap back to the right it felt weird that was for certain.
Re: 71 Charger at Hotchkis for R&D [Re: Dan@Hotchkis] #1356261
01/25/13 04:28 AM
01/25/13 04:28 AM
dangina Offline
dangina  Offline
can't wait till you get the 1.5" bars for these cars done!
Re: 71 Charger at Hotchkis for R&D [Re: dangina] #1356262
03/13/13 01:05 AM
03/13/13 01:05 AM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
Any updated pics or progress of the 71 Charger?
Also any update on parts for the 1971 - 72 B bodies, what parts are being added to the catalog? I know subframe connectors for certain. When will these parts be available?
Re: 71 Charger at Hotchkis for R&D [Re: PHJ426] #1356263
03/13/13 10:25 AM
03/13/13 10:25 AM
Owner drove the car home from the shop a couple weeks ago. We will have the car at MATS and Good Guys Del Mar. Unfortunately the car was twisted enough that I will need another car to come to the shop for test fitting subframe connectors. We have 2 designs right now.
Page 3 of 4 1 2 3 4
