Re: 71 Charger at Hotchkis for R&D
[Re: dangina]
#1356244
01/03/13 08:37 PM
01/03/13 08:37 PM
Posts: 841 Santa Fe Springs, CA
Dan@Hotchkis
my frame needed the same spot fixed as well, i wonder what caused it
There is a piece of boxing that is put in by the factory. It blocks off the channel and is a great place for crap to build up and store moisture.
[Re: Dan@Hotchkis]
#1356245
01/03/13 09:27 PM
01/03/13 09:27 PM
Posts: 3,704 MICHIGAN
DynoDave
MICHIGAN
Wow. Good catch!
For reference/education, can you post a picture of that area a little farther back, so I can better tell where it is at? Also, do you have a photo of the frame with that section removed?
[Re: Dan@Hotchkis]
#1356248
01/04/13 10:46 PM
01/04/13 10:46 PM
DynoDave
MICHIGAN
Sure. I'll snap a picture tomorrow. It's pretty easy to find because of the spot weld divots in the frame.
Thank you sir!
[Re: Dan@Hotchkis]
#1356251
01/05/13 12:52 PM
01/05/13 12:52 PM
Posts: 668 Los Osos, Ca
CKessel
Los Osos, Ca
See if you can get ahold of some of the body cavity wax/rust protection products to spray in through a hole and stop the rest from rusting out. These use a long wand that will get in and spray all over so it will all get coated. Look in Eastwood. But do it after the welding as it will contaminate the welding process.
Carl Kessel
[Re: Dan@Hotchkis]
#1356256
01/23/13 01:25 PM
01/23/13 01:25 PM
Posts: 3,456 Fly Over States
PHJ426
Fly Over States
I thought you wanted to sell some parts? Why the top secret or is there something Im not picking up since we are just typing and not face to face? Or do you mean there will be no pictures until the product is released for consumers to purchase???? Please clarify.
