Converter for 10sec pump gas 408 stroker #1346410
12/05/12 02:55 PM
12/05/12 02:55 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Just wondering what size and stall converters everyone is using behind their 408's? Obviously it is combo dependent (if you don't mind sharing that, it would be great too!) but im just trying to get an idea if my pumpgas build would be better optimized with an 8" or if something like a 9.5" would work as well. I want to spray this thing as well on the odd occasion with a 100-150 shot, but I know it is hard to get the best of both worlds.
Obviously I will call a converter manufacturer and get them to spec me what they think, but just curious to hear what others are using and what times they are running. 408, 94 pump gas motor, solid cam, 4.10 gear, 28" tire, 904, 3400lb car
Thanks!
Matthew
Re: Converter for 10sec pump gas 408 stroker [Re: mshred] #1346411
12/05/12 03:49 PM
12/05/12 03:49 PM
Wichita,ks.
jst19600 Offline
jst19600  Offline
Wichita,ks.
I have a Hughes ProComp4500 in my 72 dart 408.I run a powerglide,same gear and tire as you.Car only weighs 2800 with me in it and its run a best of 10.61.I absolutely love this converter and i gained at leat three tenths and 3 mph over my other converter.
Re: Converter for 10sec pump gas 408 stroker [Re: jst19600] #1346412
12/05/12 03:51 PM
12/05/12 03:51 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
i use a an 8" 5400 stall.
Re: Converter for 10sec pump gas 408 stroker [Re: jst19600] #1346413
12/05/12 04:02 PM
12/05/12 04:02 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
What size is that converter?
Re: Converter for 10sec pump gas 408 stroker [Re: mshred] #1346414
12/05/12 04:36 PM
12/05/12 04:36 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Mine is a little bigger at 427ci. Changed from a 9.5 edge that flashed to 5600 to a continental 8" that flashes 5600. Lost about 10lbs.! Car picked up a little more then a .10th now 10.22 @ 130. in 2200' air.
New 8" is still loose at about 9.2%, will come out soon to get tightened up. The 8" will cost more but for me it's the way to go.
"Just a Bracket car dressed up like a streetcar"
Re: Converter for 10sec pump gas 408 stroker [Re: Just-a-dart] #1346415
12/05/12 05:47 PM
12/05/12 05:47 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Pump gas 408, 3260#, 4.10 gears, 28" tire, 727, I run a 9.5" Edge that flashes 5000. Best 60' 1.38, 1.40-1 in the heat on radials.
Re: Converter for 10sec pump gas 408 stroker [Re: justinp61] #1346416
12/05/12 06:03 PM
12/05/12 06:03 PM
Renton Washington
Triple Threat Offline
Renton Washington
390"
3500#
8" PTC
4800 flash
1.47 60 foot
10.75 @ 123
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Converter for 10sec pump gas 408 stroker [Re: Triple Threat] #1346417
12/05/12 08:00 PM
12/05/12 08:00 PM
bonney lake washington
W
w2stroker Offline
w2stroker  Offline
W
i have a 9" ptc 4600 stall that was built for nitrous. only has 20 passes on it. non with spray. went 10.41 on motor alone. i'm looking to sell. pm me if you would like
Re: Converter for 10sec pump gas 408 stroker [Re: justinp61] #1346418
12/05/12 09:05 PM
12/05/12 09:05 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
What e/t's? A 9.5" would be nice if it could get me where I wanted to be
Re: Converter for 10sec pump gas 408 stroker [Re: Just-a-dart] #1346419
12/05/12 09:07 PM
12/05/12 09:07 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Sounds promising! I know different manufacturers will spec different sizes obviously depending on combo and intended usage, just trying to get ideas from everyone here as to what works for them though.
Re: Converter for 10sec pump gas 408 stroker [Re: mopar dave] #1346420
12/05/12 09:13 PM
12/05/12 09:13 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Any details on the combo?
Re: Converter for 10sec pump gas 408 stroker [Re: mshred] #1346421
12/05/12 10:11 PM
12/05/12 10:11 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
408 pump gas 3.73s 3425lbs 904 with low gear set 9.5 dynamic that flashes to 4800, best 60ft so far is 1.55 on drag radials.
I really like the convertor because I can throw 3.23s in the car and go on a trip.
But I do think an 8 inch would work better,I have one in my other street car and it works great on the street.
Re: Converter for 10sec pump gas 408 stroker [Re: mshred] #1346422
12/06/12 12:33 AM
12/06/12 12:33 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
It has ran 6.57 (1/8) in good air several times and will go 6.69-70 in street trim in the heat. I need to buy an o2 meter and tune the carb, it's pig rich.
Re: Converter for 10sec pump gas 408 stroker [Re: Darryls-Demon] #1346423
12/06/12 12:38 AM
12/06/12 12:38 AM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
Here is a 67 Barracuda 3200 lbs
408 with 4.30 gear
904 trans low gearset
30 in slicks, SS springs
8in converter 5000 stall
so far best 1.47sec 60'
10.65 1/4
Dan
Re: Converter for 10sec pump gas 408 stroker [Re: Wedgeman] #1346424
12/06/12 10:23 AM
12/06/12 10:23 AM
W
w2stroker Offline
w2stroker  Offline
W
i'm sorry i missed in the original post that you use a 904. my converter is for a 727
Re: Converter for 10sec pump gas 408 stroker [Re: w2stroker] #1346425
12/06/12 10:39 AM
12/06/12 10:39 AM
lino lakes,MN
onebaddakota Offline
lino lakes,MN
I use an 8" ATI treemaster 4800 stall. Times in sig. Calculated slip is 5.8%. It's mostly a street car. You can run an 8" on the street. Just not a cheap one.I think you'd be faster with an 8.
10.56 at 125.6, with a 1.43 60 ft. E85, Hyd. Roller 410 magnum,full exhaust, 3500 race weight.
Re: Converter for 10sec pump gas 408 stroker [Re: justinp61] #1346426
12/06/12 02:35 PM
12/06/12 02:35 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I used to run a Frank Lupo's Dynamic 9.5 inch conv 4200 stall. It would go 1.42 on motor and 1.37 on a 175 shot. This was with a 385" with a 904 low gear set and 4.56 gears with a 29/10 QTP.The car would go 10.70s on motor and 9.70s on spray. Pump gas with edelbrock RPM heads.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Converter for 10sec pump gas 408 stroker [Re: jst19600] #1346427
12/06/12 02:41 PM
12/06/12 02:41 PM
Ont. Canada
10.90 Racer Offline
super street
10.90 Racer  Offline
super street
Ont. Canada
The most important question, you might want to ask is....... What converter and what kind of slippage numbers do you get thru the traps.......
Re: Converter for 10sec pump gas 408 stroker [Re: 10.90 Racer] #1346428
12/06/12 07:21 PM
12/06/12 07:21 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I run a PTC 8in converter , but it is not a 408, its a pump gas 394ci. I was running 5.13 gears but I broke the rear at the last race.All I have is 3.50 gears I am going to try.Hope the trans does not get to hot with the high gears.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Converter for 10sec pump gas 408 stroker [Re: 10.90 Racer] #1346429
12/08/12 01:27 PM
12/08/12 01:27 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
That is definitely a good question Steve, lets throw that out there then too....Anybody care to share what slip they were seeing with their combos and the converter they used?
