Converter for 10sec pump gas 408 stroker
#1346410
12/05/12 02:55 PM
12/05/12 02:55 PM
Posts: 3,422 Toronto
mshred
Toronto
Just wondering what size and stall converters everyone is using behind their 408's? Obviously it is combo dependent (if you don't mind sharing that, it would be great too!) but im just trying to get an idea if my pumpgas build would be better optimized with an 8" or if something like a 9.5" would work as well. I want to spray this thing as well on the odd occasion with a 100-150 shot, but I know it is hard to get the best of both worlds.
Obviously I will call a converter manufacturer and get them to spec me what they think, but just curious to hear what others are using and what times they are running. 408, 94 pump gas motor, solid cam, 4.10 gear, 28" tire, 904, 3400lb car
Thanks! Matthew
Re: Converter for 10sec pump gas 408 stroker
[Re: jst19600]
#1346413
12/05/12 04:02 PM
12/05/12 04:02 PM
mshred
Toronto
I have a Hughes ProComp4500 in my 72 dart 408.I run a powerglide,same gear and tire as you.Car only weighs 2800 with me in it and its run a best of 10.61.I absolutely love this converter and i gained at leat three tenths and 3 mph over my other converter.
What size is that converter?
[Re: mshred]
#1346414
12/05/12 04:36 PM
12/05/12 04:36 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
Mine is a little bigger at 427ci. Changed from a 9.5 edge that flashed to 5600 to a continental 8" that flashes 5600. Lost about 10lbs.! Car picked up a little more then a .10th now 10.22 @ 130. in 2200' air.
New 8" is still loose at about 9.2%, will come out soon to get tightened up. The 8" will cost more but for me it's the way to go.
"Just a Bracket car dressed up like a streetcar"
[Re: justinp61]
#1346416
12/05/12 06:03 PM
12/05/12 06:03 PM
Triple Threat
Renton Washington
390" 3500# 8" PTC 4800 flash 1.47 60 foot 10.75 @ 123
[Re: justinp61]
#1346418
12/05/12 09:05 PM
12/05/12 09:05 PM
mshred
Toronto
Pump gas 408, 3260#, 4.10 gears, 28" tire, 727, I run a 9.5" Edge that flashes 5000. Best 60' 1.38, 1.40-1 in the heat on radials.
What e/t's? A 9.5" would be nice if it could get me where I wanted to be
[Re: Just-a-dart]
#1346419
12/05/12 09:07 PM
12/05/12 09:07 PM
mshred
Toronto
Sounds promising! I know different manufacturers will spec different sizes obviously depending on combo and intended usage, just trying to get ideas from everyone here as to what works for them though.
[Re: mopar dave]
#1346420
12/05/12 09:13 PM
12/05/12 09:13 PM
mshred
Toronto
i use a an 8" 5400 stall.
Any details on the combo?
[Re: mshred]
#1346422
12/06/12 12:33 AM
12/06/12 12:33 AM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
It has ran 6.57 (1/8) in good air several times and will go 6.69-70 in street trim in the heat. I need to buy an o2 meter and tune the carb, it's pig rich.
[Re: w2stroker]
#1346425
12/06/12 10:39 AM
12/06/12 10:39 AM
Posts: 226 lino lakes,MN
onebaddakota
lino lakes,MN
I use an 8" ATI treemaster 4800 stall. Times in sig. Calculated slip is 5.8%. It's mostly a street car. You can run an 8" on the street. Just not a cheap one.I think you'd be faster with an 8.
10.56 at 125.6, with a 1.43 60 ft.
E85, Hyd. Roller 410 magnum,full exhaust, 3500 race weight.
[Re: justinp61]
#1346426
12/06/12 02:35 PM
12/06/12 02:35 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I used to run a Frank Lupo's Dynamic 9.5 inch conv 4200 stall. It would go 1.42 on motor and 1.37 on a 175 shot. This was with a 385" with a 904 low gear set and 4.56 gears with a 29/10 QTP.The car would go 10.70s on motor and 9.70s on spray. Pump gas with edelbrock RPM heads.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: jst19600]
#1346427
12/06/12 02:41 PM
12/06/12 02:41 PM
Posts: 1,409 Ont. Canada
10.90 Racer
super street
super street
Ont. Canada
The most important question, you might want to ask is....... What converter and what kind of slippage numbers do you get thru the traps.......
[Re: 10.90 Racer]
#1346428
12/06/12 07:21 PM
12/06/12 07:21 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I run a PTC 8in converter , but it is not a 408, its a pump gas 394ci. I was running 5.13 gears but I broke the rear at the last race.All I have is 3.50 gears I am going to try.Hope the trans does not get to hot with the high gears.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: 10.90 Racer]
#1346429
12/08/12 01:27 PM
12/08/12 01:27 PM
mshred
Toronto
That is definitely a good question Steve, lets throw that out there then too....Anybody care to share what slip they were seeing with their combos and the converter they used?
