Re: Engine Install from below . . . .
[Re: a12rag]
#1294779
08/31/12 10:02 PM
08/31/12 10:02 PM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
That's very clever on your dual purpose dolly/lifting harness. Also, the black-out on the radiator yoke looks good. Can't stand that body color showing through the grille.
[Re: a12rag]
#1294782
08/31/12 11:01 PM
08/31/12 11:01 PM
Posts: 15,926 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Good info, and wow, what a beautiful car! Congrats!
Facts are stubborn things.
[Re: bobs66440]
#1294783
09/01/12 12:02 PM
09/01/12 12:02 PM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
That looks pretty good. I have a dumb question though. Once you have lowered the car down over the engine, how do you get the bolts into the trans cross member? How do you fit under there to get the bolts started?? Do you just bolt up the K-Frame and let the back of the engine hang until you get the car raised enough to fit under??
It's much easier to get all the bolts lined up and caught if the car is level.
Note how I use jack stands under the rear axle. Once the front end is lowered the K member bolts and the trans X member bolts are very close to lining up. Once you've done it a few times you can devise a few short cuts, like how high the axle needs to be off the ground.
[Re: RSNOMO]
#1294785
09/01/12 05:15 PM
09/01/12 05:15 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Does this pertain to all years of RWD Mopars? I am wondering about my 80's M and F body cars.
Thanks.
[Re: larrymopar360]
#1294786
09/01/12 07:40 PM
09/01/12 07:40 PM
Posts: 27,471 So Cal
autoxcuda
So Cal
Thanks.
Even better for F/M/J cars. With those cars the T-bars, shocks, upper control arms are all contained in the K-member.
I heard some hot rodder like to used F/M/J k-member setups because everything is so self contained.
