Engine Install from below . . . . #1294773
08/31/12 08:04 PM
08/31/12 08:04 PM
Calgary, Alberta Canada
a12rag Offline OP
a12rag  Offline OP
I have not installed an drivetrain and suspension from below before, and was kinda nervous about the whole thing . . . and sure is no need to be now !! Had a couple of buddies help me a few nights ago, and we go it installed and on 4 wheels in about 3 hours !!! No need to remove the hood, no scratches and all went well.
If you are planning to do this yourself - go for it !!! I made the front cradle/dolley that the car was sitting on. It has casters on it, and the cross piece was far enough out so that when turned 90 degrees, it was used for lifting point to raise the car with the engine hoist.
Mark
Re: Engine Install from below . . . . [Re: a12rag] #1294774
08/31/12 08:06 PM
08/31/12 08:06 PM
a12rag Offline OP
a12rag  Offline OP
Another pic . . . the big black blob on top front of engine is factory RV2 A/C compressor . . . yup, factory a/c car !
Re: Engine Install from below . . . . [Re: a12rag] #1294775
08/31/12 08:07 PM
08/31/12 08:07 PM
a12rag Offline OP
a12rag  Offline OP
Engine in . . .
Re: Engine Install from below . . . . [Re: a12rag] #1294776
08/31/12 08:09 PM
08/31/12 08:09 PM
a12rag Offline OP
a12rag  Offline OP
And finally rolling on all four tires . . .
Re: Engine Install from below . . . . [Re: a12rag] #1294777
08/31/12 08:26 PM
08/31/12 08:26 PM
SE Pa.
LimeliteAero Offline
SE Pa.
good job!!! Thanks for posting, I'll be doing the same thing in a few months. (I hope!)
I love the wheel choice too!
Re: Engine Install from below . . . . [Re: LimeliteAero] #1294778
08/31/12 09:07 PM
08/31/12 09:07 PM
a12rag Offline OP
a12rag  Offline OP
Thanks . . . will have to give a plug to Specialty Wheel - 15x7 Powder coat paint black on outside of rim, just like 14" !!! . . .
Now, what to do with my cradle/dolly ??? . . .
Good luck with your install !
Mark
Re: Engine Install from below . . . . [Re: a12rag] #1294779
08/31/12 10:02 PM
08/31/12 10:02 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
That's very clever on your dual purpose dolly/lifting harness.
Also, the black-out on the radiator yoke looks good.
Can't stand that body color showing through the grille.
Re: Engine Install from below . . . . [Re: a12rag] #1294780
08/31/12 10:34 PM
08/31/12 10:34 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
See video of a similar install:
http://www.moparaction.com/Tech/Savoy/savoy.wmv
No other rational way to do it!
Rick
Re: Engine Install from below . . . . [Re: Rick_Ehrenberg] #1294781
08/31/12 10:55 PM
08/31/12 10:55 PM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
That looks pretty good. I have a dumb question though. Once you have lowered the car down over the engine, how do you get the bolts into the trans cross member? How do you fit under there to get the bolts started?? Do you just bolt up the K-Frame and let the back of the engine hang until you get the car raised enough to fit under??
Re: Engine Install from below . . . . [Re: a12rag] #1294782
08/31/12 11:01 PM
08/31/12 11:01 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Good info, and wow, what a beautiful car! Congrats!
Facts are stubborn things.
Re: Engine Install from below . . . . [Re: bobs66440] #1294783
09/01/12 12:02 PM
09/01/12 12:02 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
It's much easier to get all the bolts lined up and caught if the car is level.
Note how I use jack stands under the rear axle. Once the front end is lowered the K member bolts and the trans X member bolts are very close to lining up. Once you've done it a few times you can devise a few short cuts, like how high the axle needs to be off the ground.
Re: Engine Install from below . . . . [Re: a12rag] #1294784
09/01/12 01:58 PM
09/01/12 01:58 PM
RSNOMO Online rolleyes
Moparts Torchbearer
RSNOMO  Online Rolleyes
Moparts Torchbearer
Absolutely the only way to do it...
Re: Engine Install from below . . . . [Re: RSNOMO] #1294785
09/01/12 05:15 PM
09/01/12 05:15 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Does this pertain to all years of RWD Mopars? I am wondering about my 80's M and F body cars.
Thanks.
Re: Engine Install from below . . . . [Re: larrymopar360] #1294786
09/01/12 07:40 PM
09/01/12 07:40 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Thanks.
Even better for F/M/J cars. With those cars the T-bars, shocks, upper control arms are all contained in the K-member.
I heard some hot rodder like to used F/M/J k-member setups because everything is so self contained.
Re: Engine Install from below . . . . [Re: autoxcuda] #1294787
09/01/12 08:23 PM
09/01/12 08:23 PM
wisconsin
1BAD68 Offline
1BAD68  Offline
wisconsin
What about brake lines, alignment, etc.?
