Re: 69 Road Runner seat medallions long or short?
[Re: satgtx]
#124072
09/21/08 09:43 PM
09/21/08 09:43 PM
Posts: 21,548 N.E. OHIO, USA
A12
N.E. OHIO, USA
Bench seat 69 RR seat medallions? which was correct the long skinny ones or the shorter fat ones? or was there a date switch over form short to long? i have seen both but what was correct? Was the front different then the back?
I've seen both on '69's also and with no rhyme or reason. The '68's mostly (all?) seem to be the long version, my '69-1/2 A12 RR with black interior are original and long. A '69 Hemi RR "survivor" that is always at the Nat's has the long version on a green interior. They are, or should be, the same front and rear regardless of long or short. Little rant here from me "why doesn't Legendary Interiors or someone make reproduction seat medallions with the number of Mopars that used them?" Seems like an added money maker when you sell a set of covers IMO ![](/ubbthreads/images/graemlins/rant.gif)
MikeR
[Re: 6PakBee]
#124074
09/21/08 11:31 PM
09/21/08 11:31 PM
Posts: 2,230 restos just aren't my thing
gtsuperbee
they shoud be long and match the color interior. check out www.a12mopar.com and go to the "lift off forum". search around. there are definitely some pics over there.
Restoring a car to look "only" as good as the factory made it is like getting a boob job for your wife and having the doctor make them two different sizes to seem more natural
[Re: satgtx]
#124076
09/22/08 02:55 PM
09/22/08 02:55 PM
Posts: 1,109 Hiram, Georgia
474218
Hiram, Georgia
ok, i will pass this info on. most folks say they have seen them both ways, So short for 68 and long for 69 or was it what ever was available.
My 69 RR came with the short medallions.
[Re: 474218]
#124077
09/22/08 03:56 PM
09/22/08 03:56 PM
A12
N.E. OHIO, USA
I wonder if the assembly plant made a difference? Most of the long versions I've seen on RR's (i.e, A12's) have been on Lynch Road (A) built cars to around 9A30XXXX VIN's. Which plant was your RR built in? My A12 RR was an early May '69 build with a 9A27XXXX VIN (long medallions) and June built Lynch Road cars were in the 9A28XXXX - 9A30XXXX IIRC? Maybe we can figure out a ballpark change over at least at one plant? And this doesn't need to be just RR's right, didn't the Satellite's also use the same "decor" medallions?
MikeR
[Re: 6PakBee]
#124079
09/22/08 07:50 PM
09/22/08 07:50 PM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
Here is a pic of those medallions. I am betting there was a couple of vendors for these. This photo was posted the last time someone asked about them.
[Re: 474218]
#124080
09/22/08 10:00 PM
09/22/08 10:00 PM
Posts: 3,407 S.E. Florida, USA
rrunner
S.E. Florida, USA
All I've owned also.
[Re: sthemi]
#124082
09/22/08 11:45 PM
09/22/08 11:45 PM
474218
Hiram, Georgia
If you have ever taken one apart you will appreciate Mopar engineering. I don't know if a vendor would want to take on such a project.
Starting on the back side: There is a a base plate with two studs. Next is the raised center part with the vinyl molded to it. Then the outer chrome trim. All three parts are crimped together. It is attached to the seat with backing plate that is a one time use item.
Addtionally, the lower picture is not a 69 RR, the medallions are further apart on the 69's. I am almost positive that medallions in the picture are from a 68 RR.
[Re: 474218]
#124083
09/23/08 12:15 AM
09/23/08 12:15 AM
A12
N.E. OHIO, USA
I can confirm that statement because that's my photo(s) and that's my '68 rear seat back with the tape measure. The top photo is from the '69 Hemi RR survivor and taken at Carlisle and they are a little wider as you pointed out but still seem to be longer than another medallion that is also out there.
So '68 RR medallions are long and the thinnest and '69 RR medallions are about the same lenght but slightly wider.........
MikeR
