Here is a pic of those medallions.
I am betting there was a couple of vendors for these.
This photo was posted the last time someone asked about them.
If you have ever taken one apart you will appreciate Mopar engineering. I don't know if a vendor would want to take on such a project.
Starting on the back side: There is a a base plate with two studs. Next is the raised center part with the vinyl molded to it. Then the outer chrome trim. All three parts are crimped together. It is attached to the seat with backing plate that is a one time use item.
Addtionally, the lower picture is not a 69 RR, the medallions are further apart on the 69's. I am almost positive that medallions in the picture are from a 68 RR.
