69 Road Runner seat medallions long or short? #124071
09/21/08 08:15 PM
09/21/08 08:15 PM
Maryland, USA,
satgtx Offline OP
satgtx  Offline OP
Maryland, USA,
Bench seat 69 RR seat medallions? which was correct the long skinny ones or the shorter fat ones? or was there a date switch over form short to long? i have seen both but what was correct? Was the front different then the back?
Re: 69 Road Runner seat medallions long or short? [Re: satgtx] #124072
09/21/08 09:43 PM
09/21/08 09:43 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I've seen both on '69's also and with no rhyme or reason. The '68's mostly (all?) seem to be the long version, my '69-1/2 A12 RR with black interior are original and long. A '69 Hemi RR "survivor" that is always at the Nat's has the long version on a green interior. They are, or should be, the same front and rear regardless of long or short. Little rant here from me "why doesn't Legendary Interiors or someone make reproduction seat medallions with the number of Mopars that used them?" Seems like an added money maker when you sell a set of covers IMO
MikeR
Re: 69 Road Runner seat medallions long or short? [Re: A12] #124073
09/21/08 10:37 PM
09/21/08 10:37 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Picture?
Re: 69 Road Runner seat medallions long or short? [Re: 6PakBee] #124074
09/21/08 11:31 PM
09/21/08 11:31 PM
restos just aren't my thing
gtsuperbee Offline
gtsuperbee  Offline
they shoud be long and match the color interior. check out www.a12mopar.com and go to the "lift off forum". search around. there are definitely some pics over there.
Restoring a car to look "only" as good as the factory made it is like getting a boob job for your wife and having the doctor make them two different sizes to seem more natural
Re: 69 Road Runner seat medallions long or short? [Re: gtsuperbee] #124075
09/22/08 01:23 PM
09/22/08 01:23 PM
Maryland, USA,
satgtx Offline OP
satgtx  Offline OP
Maryland, USA,
ok, i will pass this info on. most folks say they have seen them both ways, So short for 68 and long for 69 or was it what ever was available.
Re: 69 Road Runner seat medallions long or short? [Re: satgtx] #124076
09/22/08 02:55 PM
09/22/08 02:55 PM
Hiram, Georgia
474218 Offline
474218  Offline
Hiram, Georgia
My 69 RR came with the short medallions.
Re: 69 Road Runner seat medallions long or short? [Re: 474218] #124077
09/22/08 03:56 PM
09/22/08 03:56 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I wonder if the assembly plant made a difference? Most of the long versions I've seen on RR's (i.e, A12's) have been on Lynch Road (A) built cars to around 9A30XXXX VIN's. Which plant was your RR built in? My A12 RR was an early May '69 build with a 9A27XXXX VIN (long medallions) and June built Lynch Road cars were in the 9A28XXXX - 9A30XXXX IIRC? Maybe we can figure out a ballpark change over at least at one plant? And this doesn't need to be just RR's right, didn't the Satellite's also use the same "decor" medallions?
MikeR
Re: 69 Road Runner seat medallions long or short? [Re: 474218] #124078
09/22/08 05:21 PM
09/22/08 05:21 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Thanks! Appreciate the help.
Re: 69 Road Runner seat medallions long or short? [Re: 6PakBee] #124079
09/22/08 07:50 PM
09/22/08 07:50 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Here is a pic of those medallions.
I am betting there was a couple of vendors for these.
This photo was posted the last time someone asked about them.
Re: 69 Road Runner seat medallions long or short? [Re: 474218] #124080
09/22/08 10:00 PM
09/22/08 10:00 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
All I've owned also.
Re: 69 Road Runner seat medallions long or short? [Re: rrunner] #124081
09/22/08 11:29 PM
09/22/08 11:29 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
The long ones went in a 69 RR..not too much interest in the short ones.
Re: 69 Road Runner seat medallions long or short? [Re: sthemi] #124082
09/22/08 11:45 PM
09/22/08 11:45 PM
Hiram, Georgia
474218 Offline
474218  Offline
Hiram, Georgia
If you have ever taken one apart you will appreciate Mopar engineering. I don't know if a vendor would want to take on such a project.
Starting on the back side: There is a a base plate with two studs. Next is the raised center part with the vinyl molded to it. Then the outer chrome trim. All three parts are crimped together. It is attached to the seat with backing plate that is a one time use item.
Addtionally, the lower picture is not a 69 RR, the medallions are further apart on the 69's. I am almost positive that medallions in the picture are from a 68 RR.
Re: 69 Road Runner seat medallions long or short? [Re: 474218] #124083
09/23/08 12:15 AM
09/23/08 12:15 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I can confirm that statement because that's my photo(s) and that's my '68 rear seat back with the tape measure. The top photo is from the '69 Hemi RR survivor and taken at Carlisle and they are a little wider as you pointed out but still seem to be longer than another medallion that is also out there.
So '68 RR medallions are long and the thinnest and '69 RR medallions are about the same lenght but slightly wider.........
MikeR
Re: 69 Road Runner seat medallions long or short? [Re: A12] #124084
09/23/08 12:19 AM
09/23/08 12:19 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
this was also in the group of photos taken at Carlisle and I think it's from a '69 RR too....this is getting so confusing as they look like what should be '68's
Re: 69 Road Runner seat medallions long or short? [Re: A12] #124085
09/23/08 08:10 AM
09/23/08 08:10 AM
Maryland, USA,
satgtx Offline OP
satgtx  Offline OP
Maryland, USA,
i am thinking it was what ever was available. several vendors with slight differences.
