Re: short tailshaft
[Re: 67cudagreg]
#123874
09/21/08 08:39 AM
09/21/08 08:39 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Trucks with extended cab spit drive shaft and 4X4 trucks with divorced transfer cases. RV but then you will run into the E brake on the transmission tail.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
Re: short tailshaft
[Re: 67cudagreg]
#123876
09/21/08 10:27 AM
09/21/08 10:27 AM
Posts: 1,406 New Jersey, USA
yella71
New Jersey, USA
I saw one once in, beleave it or not, a street sweeper. It had a 318 to run the truck with a very short tail(about 6 or 8 inches) with no brake on the end. Look for an industral or truck application in the salvage yards.
71 challenger convertable, 64 sport fury 383 ci with factory air
99 sebring convertable
89 CTD pup
Re: short tailshaft
[Re: 67cudagreg]
#123879
09/21/08 04:10 PM
09/21/08 04:10 PM
Posts: 25,757 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The factory short tails use a fixed yoke instead of a slip yoke, so provisions need to be made in the driveline to allow movement.
Most are about 5" shorter than the standard passenger car housing.
Re: short tailshaft
[Re: 67cudagreg]
#123880
09/21/08 04:41 PM
09/21/08 04:41 PM
MoparforLife
Upper Midwest
I have a 904 for mockup and it is perfect @ 4'' shorter than the 727,but I wanted to use the 727 I have because it is fresh and the 904 needs to be redone and a new converter
It would have to come all apart to put the tail shaft and housing on anyway.
Re: short tailshaft
[Re: 67cudagreg]
#123882
09/22/08 08:01 AM
09/22/08 08:01 AM
Posts: 74,979 U.S.S.A.
JohnRR
U.S.S.A.
Are you running a big block or smallblock ?
Re: short tailshaft
[Re: GLR]
#123884
09/22/08 10:13 AM
09/22/08 10:13 AM
Posts: 15,487 Florida
scratchnfotraction
I have one from a 76 dodge truck club cab has a short shaft with bolt on yoke I used it in a 68 dodge Dart at one time,just built a drive shaft with a slip yoke had it in an 85 truck short bed till the sprag went they are called a loadflight in the trucks supposedly has 4 plantary gears and the extra clutches or something along that line
