short tailshaft #123873
09/21/08 07:50 AM
09/21/08 07:50 AM
Dryden,MI,USA
67cudagreg Offline OP
Dryden,MI,USA
I am building a mopar hot rod that is going to have a very short drive shaft .I have read somewhere that chrysler made a 727 trans with a short tail shaft. does anybody know about the availabilty of this tailshaft? thanks
Re: short tailshaft [Re: 67cudagreg] #123874
09/21/08 08:39 AM
09/21/08 08:39 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Trucks with extended cab spit drive shaft and 4X4 trucks with divorced transfer cases. RV but then you will run into the E brake on the transmission tail.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: short tailshaft [Re: MoparforLife] #123875
09/21/08 09:57 AM
09/21/08 09:57 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
One could eliminate the e brake on the trans tail I would assume , I have one of those trans but no truck output flange to see if it will fit .
To the OP how short do you need the tail to be ?
Re: short tailshaft [Re: 67cudagreg] #123876
09/21/08 10:27 AM
09/21/08 10:27 AM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
I saw one once in, beleave it or not, a street sweeper. It had a 318 to run the truck with a very short tail(about 6 or 8 inches) with no brake on the end. Look for an industral or truck application in the salvage yards.
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: short tailshaft [Re: MoparforLife] #123877
09/21/08 11:35 AM
09/21/08 11:35 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I had ones out of van-front motorhomes that were a short one with no ebrake on the end too before..
Re: short tailshaft [Re: JohnRR] #123878
09/21/08 01:31 PM
09/21/08 01:31 PM
Dryden,MI,USA
Dryden,MI,USA
I have a 904 for mockup and it is perfect @ 4'' shorter than the 727,but I wanted to use the 727 I have because it is fresh and the 904 needs to be redone and a new converter
Re: short tailshaft [Re: 67cudagreg] #123879
09/21/08 04:10 PM
09/21/08 04:10 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The factory short tails use a fixed yoke instead of a slip yoke, so provisions need to be made in the driveline to allow movement.
Most are about 5" shorter than the standard passenger car housing.
Re: short tailshaft [Re: 67cudagreg] #123880
09/21/08 04:41 PM
09/21/08 04:41 PM
Upper Midwest
Upper Midwest
It would have to come all apart to put the tail shaft and housing on anyway.
Re: short tailshaft [Re: MoparforLife] #123881
09/21/08 10:25 PM
09/21/08 10:25 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
B&M used to make a short tail kit for the 727 that used a slip yoke. Maybe you could get lucky and find one on E-bag.
Re: short tailshaft [Re: 67cudagreg] #123882
09/22/08 08:01 AM
09/22/08 08:01 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Are you running a big block or smallblock ?
Re: short tailshaft [Re: JohnRR] #123883
09/22/08 09:54 AM
09/22/08 09:54 AM
Northern Pa
GLR Offline
GLR  Offline
Northern Pa
There is a short tail 727 on my 1985 Dodge truck it is a 2WD crew cab 1 ton.
Re: short tailshaft [Re: GLR] #123884
09/22/08 10:13 AM
09/22/08 10:13 AM
scratchnfotraction Offline
I have one from a 76 dodge truck club cab
has a short shaft with bolt on yoke
I used it in a 68 dodge Dart at one time,just built a drive shaft with a slip yoke
had it in an 85 truck short bed till the sprag went
they are called a loadflight in the trucks
supposedly has 4 plantary gears and the extra clutches or something along that line
