Re: Going to the Dyno in the AM...Guess the HP [Re: Mr.Yuck] #1213725
04/11/12 04:24 PM
04/11/12 04:24 PM
SoCal
Brian Hafliger Offline
SoCal
Based on my setup, mine yours
440 496
solid .590 roller .640
comp 12.7.1 10.5.1
intake victor SD
carb 950 950
heads MCH RPM's on both
mine approx 600 hp yours 630 hp
how can you say a guy that has 56 more cubic inches is only going to make 30 more hp?
2pts. compression is part of it...
Brian Hafliger
Re: Going to the Dyno in the AM...Guess the HP [Re: A70Runner] #1213726
04/11/12 04:27 PM
04/11/12 04:27 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
[Email]610@5700[/Email] and climbing before rocker shaft problems ended the day.
i think the engine gains 10hp per 100 more rpm on the dyno +/- to what the cam,carb,heads will allow.
Re: Going to the Dyno in the AM...Guess the HP [Re: RAMM] #1213727
04/12/12 11:20 AM
04/12/12 11:20 AM
Mooresville, NC
A70Runner Offline OP
Mooresville, NC
What was the nature of the problem? What was the torque looking like? J.Rob
Seized the rockers to the shafts. tq 598@4900
"People Think I'm Insane Because I Am Frowning All The Time" Black Sabbath
Re: Going to the Dyno in the AM...Guess the HP [Re: A70Runner] #1213728
04/12/12 11:26 AM
04/12/12 11:26 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Seized the rockers to the shafts. tq [Email]598@4900[/Email]
ouch.
Re: Going to the Dyno in the AM...Guess the HP [Re: A70Runner] #1213729
04/12/12 11:35 AM
04/12/12 11:35 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
how does that happen? lack of oil? I would think they'd make a bunch on noise before they siezed up...
Re: Going to the Dyno in the AM...Guess the HP [Re: A70Runner] #1213730
04/12/12 11:44 AM
04/12/12 11:44 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Sorry about your luck... I have some new rockers for sale in classifieds.
Re: Going to the Dyno in the AM...Guess the HP [Re: Mr.Yuck] #1213731
04/12/12 11:49 AM
04/12/12 11:49 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Possible the springs are too stiff for those rockers ?
Have you ever dynoed and engine or been present for one ? You aren't in the room with the engine, headers are usually open, there is a lot of noise .
Re: Going to the Dyno in the AM...Guess the HP [Re: JohnRR] #1213732
04/12/12 12:09 PM
04/12/12 12:09 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
In his case using rockers rated below the spring pressure.
Have you ever dynoed and engine or been present for one ? YOu aren't in the room with the engine , headers are usually open , there is a lot of noise .
just chassis dyno.
Re: Going to the Dyno in the AM...Guess the HP [Re: JohnRR] #1213733
04/12/12 12:10 PM
04/12/12 12:10 PM
Mooresville, NC
Mooresville, NC
Just talked to Comp. They said those rockers should be fine with my spring pressures.(or at least the new design ones.)
Re: Going to the Dyno in the AM...Guess the HP [Re: A70Runner] #1213734
04/12/12 12:27 PM
04/12/12 12:27 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I thought this came up before and that 500 was the number ?? Are yours considered the new design ?
Mods to your rocker oiling ???
Are they going to warranty them ?
Re: Going to the Dyno in the AM...Guess the HP [Re: A70Runner] #1213735
04/12/12 06:04 PM
04/12/12 06:04 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Are these the Comp Pro Magnums? Seems like a few people were having those rockers bushed due to the steel-against- steel galling..... Never mind, i see you have started another post.
Re: Going to the Dyno in the AM...Guess the HP [Re: forphorty] #1213736
04/12/12 06:34 PM
04/12/12 06:34 PM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
my 440 made 590ftlb at 4800 but stopped at 605 at 5800 cam at 104 solid. now at 108 and it picked up a strong >4 to .5 in the 1/4.
i may put it in at 110 this season.....
Re: Going to the Dyno in the AM...Guess the HP [Re: dmking] #1213737
07/22/12 04:12 PM
07/22/12 04:12 PM
Mooresville, NC
Mooresville, NC
Ok finally got back to the dyno. Same combination execept Harlond Sharp rockers......
657.5 hp @ 6100
638.6 tq @ 4800
on Sunoco 93!!
Video of pull
Tried a M1 with 1" spacer on it also....
ran 1 hp under the sd. The sd had a more straight curve to it. the m1 was very choppy. Sorry can't find the sheet right now for the M1 so no exact numbers.
All in all made 16 pulls yesterday. Only "scare" was losing 50hp on the first run with the M1. found a piece of bowl gasket in the front jet. No harm no foul!!
Very Happy!!!
Re: Going to the Dyno in the AM...Guess the HP [Re: A70Runner] #1213738
07/22/12 05:02 PM
07/22/12 05:02 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Nice numbers.
Wondering what your .050 duration numbers are on the cam?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Going to the Dyno in the AM...Guess the HP [Re: Von] #1213739
07/23/12 01:16 PM
07/23/12 01:16 PM
NJ
JCCuda Offline
JCCuda  Offline
NJ
Hey Jim congrats on finally get that thing running on the dyno. Made some good numbers Todd and Duane were keeping me posted. I unfortunately was working in an attic (the exciting life of an HVAC guy) in Toms River while you guys were having fun. I couldn't believe that the M1 wasn't a little better than the SD. Now hurry up and get it in the car and see what it does. I'm saying 10.50 at 127-128. Good luck. And tell us what the @.050 numbers are and the lobe seperation.
