Going to the Dyno in the AM...Guess the HP
#1213705
04/10/12 05:58 PM
04/10/12 05:58 PM
Posts: 971 Mooresville, NC
A70Runner
Mooresville, NC
Going to dyno my 496 tommrow. I am so exited!!! Just wondering what everyone thinks it will make for tq/HP Specs 496 Using Muscle Motors kit. Should be little north of 10-1 Compression Edelbrock head CNC ported by Modern Cylinder heads. Flow 328int/268ex. Solid Roller cam by Straighline w 1.5 rockers. Intake .645 Duration 300 Centerline@108Ex. .626 Duration 314 Centerline @116 Intake is a ported Holley SD to clear my hood on my RR. Also going to try a M1 on the dyno 950 Demon for a carb.
"People Think I'm Insane Because I Am Frowning All The Time" Black Sabbath
Re: Going to the Dyno in the AM...Guess the HP
[Re: A70Runner]
#1213706
04/10/12 06:47 PM
04/10/12 06:47 PM
Posts: 860 lancaster,california
johnnycuda
I'm assuming SD stands for Strip Dominator,I'll guess between 610-650 hp range,,what headers are being used?,,2inch primaries?
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
[Re: Mr.Yuck]
#1213713
04/11/12 08:28 AM
04/11/12 08:28 AM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
I'd be shocked if it doesn't make 650+
prepare yourself then,i think 580/600hp but if it was on alky i would be there with you.
[Re: Clanton]
#1213716
04/11/12 09:34 AM
04/11/12 09:34 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
I've never been to the dyno, but I'm guessing I'm around 570ish and he has WAY more engine than I have...and 50 more cubic inches.
[Re: Mr.Yuck]
#1213718
04/11/12 11:17 AM
04/11/12 11:17 AM
Posts: 9,875 Weddington, N.C.
Streetwize
Weddington, N.C.
Roller lift/duration is well matched to the Modern CNC eddies. If the SD is ported like I do them that motor should EASILY make at least 635-640 Hp and either way it's gonna be a near perfect street/strip brawler, perfect for 3.54 gears. Out of the box a SD will flow around 270, ported they can go over 310. Very similar to my old 508 which was a 610hp recipie with a 252/258 straight line hydraulic roller and ported iron Stage V heads. Either way, I like the combo a lot but I'd prefer (having run both) the tighter 108 lobe spread for a little more "hit" in the 2500-4500 'fun zone'. Nice combo....I predict.... happiness
[Re: MR_P_BODY]
#1213720
04/11/12 11:53 AM
04/11/12 11:53 AM
Posts: 3,210 robin hood country
deaks
robin hood country
Based on my setup, mine yours 440 496 solid .590 roller .640 comp 12.7.1 10.5.1 intake victor SD carb 950 950 heads MCH RPM's on both mine approx 600 hp yours 630 hp
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: deaks]
#1213721
04/11/12 12:07 PM
04/11/12 12:07 PM
Mr.Yuck
Brookeville, Md
how can you say a guy that has 56 more cubic inches is only going to make 30 more hp?
[Re: dogdays]
#1213723
04/11/12 01:52 PM
04/11/12 01:52 PM
A70Runner
Mooresville, NC
610@5700 and climbing before rocker shaft problems ended the day.
[Re: A70Runner]
#1213724
04/11/12 02:05 PM
04/11/12 02:05 PM
Posts: 1,051 The Great White North
RAMM
What was the nature of the problem? What was the torque looking like? J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
