Going to the Dyno in the AM...Guess the HP #1213705
04/10/12 05:58 PM
04/10/12 05:58 PM
Mooresville, NC
A70Runner Offline OP
Mooresville, NC
Going to dyno my 496 tommrow. I am so exited!!! Just wondering what everyone thinks it will make for tq/HP
Specs
496 Using Muscle Motors kit. Should be little north of 10-1 Compression
Edelbrock head CNC ported by Modern Cylinder heads. Flow 328int/268ex.
Solid Roller cam by Straighline
w 1.5 rockers.
Intake .645 Duration 300 Centerline@108
Ex. .626 Duration 314 Centerline @116
Intake is a ported Holley SD to clear my hood on my RR. Also going to try a M1 on the dyno
950 Demon for a carb.
"People Think I'm Insane Because I Am Frowning All The Time" Black Sabbath
Re: Going to the Dyno in the AM...Guess the HP [Re: A70Runner] #1213706
04/10/12 06:47 PM
04/10/12 06:47 PM
lancaster,california
johnnycuda Offline
johnnycuda  Offline
I'm assuming SD stands for Strip Dominator,I'll guess between 610-650 hp range,,what headers are being used?,,2inch primaries?
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT!
1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air,
New daily driver-2003 Ram 2500 Cummins 5.9
'69 Valiant 2-dr, sleeper!
New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: Going to the Dyno in the AM...Guess the HP [Re: johnnycuda] #1213707
04/10/12 07:17 PM
04/10/12 07:17 PM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
622hp corrected
Re: Going to the Dyno in the AM...Guess the HP [Re: A70Runner] #1213708
04/10/12 07:58 PM
04/10/12 07:58 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
620 hp 640 tq
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: Going to the Dyno in the AM...Guess the HP [Re: A70Runner] #1213709
04/10/12 08:15 PM
04/10/12 08:15 PM
NJ
JCCuda Offline
JCCuda  Offline
NJ
Hey Jim good luck tomorrow. I wanted to go with Todd but couldn't get off from work. Any normal 496 like yours would probably make about 600 hp but with the Hoven brothers working on it I'll have to say 685 hp and 575 ft.lbs.
Re: Going to the Dyno in the AM...Guess the HP [Re: JCCuda] #1213710
04/10/12 08:55 PM
04/10/12 08:55 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
690....
Re: Going to the Dyno in the AM...Guess the HP [Re: jim sciortino] #1213711
04/11/12 12:31 AM
04/11/12 12:31 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I was thinking about 625. Ron
Re: Going to the Dyno in the AM...Guess the HP [Re: 383man] #1213712
04/11/12 08:22 AM
04/11/12 08:22 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'd be shocked if it doesn't make 650+
Coming soon!!!!
Re: Going to the Dyno in the AM...Guess the HP [Re: Mr.Yuck] #1213713
04/11/12 08:28 AM
04/11/12 08:28 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
prepare yourself then,i think 580/600hp but if it was on alky i would be there with you.
Re: Going to the Dyno in the AM...Guess the HP [Re: A70Runner] #1213714
04/11/12 08:35 AM
04/11/12 08:35 AM
gregsdart Offline
gregsdart  Offline
Good luck with it! For sure it will put a smile on your face when you get it in the car!
Re: Going to the Dyno in the AM...Guess the HP [Re: gregsdart] #1213715
04/11/12 09:30 AM
04/11/12 09:30 AM
Trumbull,CT.
Trumbull,CT.
In the early 90s we had a 499ci with a set of 906s that my brother ported, an M1 /with a 9375 1050, a solid lifter cam and 2" fenderwells.
On it's 1st outing at ATCO, in ran a string of 10ohs at 135 change. The car had SS prings, footbraked and weighed 3380.
We never dynoed that one because it was just a lowbuck streetcar. Your engine has to make more than that thing did.
Re: Going to the Dyno in the AM...Guess the HP [Re: Clanton] #1213716
04/11/12 09:34 AM
04/11/12 09:34 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I've never been to the dyno, but I'm guessing I'm around 570ish and he has WAY more engine than I have...and 50 more cubic inches.
Re: Going to the Dyno in the AM...Guess the HP [Re: A70Runner] #1213717
04/11/12 11:13 AM
04/11/12 11:13 AM
Specs
w 1.5 rockers.
Intake .645 Duration 300 [Email]Centerline@108[/Email]
The cam looks like a blower or NOS cam so my guess testing it N/A will be around 650, maybe as high as 675 HP and 610 to 630 Ft Lbs My 505 with Jeffs CNC RPM heads made 687 HP at 5900 RPM with a 1050 Dominator on a M1 and 1.0 inch open phenolic spacer with a lot smaller roller cam Good luck
Re: Going to the Dyno in the AM...Guess the HP [Re: Mr.Yuck] #1213718
04/11/12 11:17 AM
04/11/12 11:17 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Roller lift/duration is well matched to the Modern CNC eddies. If the SD is ported like I do them that motor should EASILY make at least 635-640 Hp and either way it's gonna be a near perfect street/strip brawler, perfect for 3.54 gears. Out of the box a SD will flow around 270, ported they can go over 310.
Very similar to my old 508 which was a 610hp recipie with a 252/258 straight line hydraulic roller and ported iron Stage V heads. Either way, I like the combo a lot but I'd prefer (having run both) the tighter 108 lobe spread for a little more "hit" in the 2500-4500 'fun zone'.
Nice combo....I predict.... happiness
WIZE
In Car:
Re: Going to the Dyno in the AM...Guess the HP [Re: Cab_Burge] #1213719
04/11/12 11:43 AM
04/11/12 11:43 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Scott really likes to run 112 lsa cams... I have one
of his cams also and its a 112 lsa
Re: Going to the Dyno in the AM...Guess the HP [Re: MR_P_BODY] #1213720
04/11/12 11:53 AM
04/11/12 11:53 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Based on my setup, mine yours
440 496
solid .590 roller .640
comp 12.7.1 10.5.1
intake victor SD
carb 950 950
heads MCH RPM's on both
mine approx 600 hp yours 630 hp
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Going to the Dyno in the AM...Guess the HP [Re: deaks] #1213721
04/11/12 12:07 PM
04/11/12 12:07 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
440 496
comp 12.7.1 10.5.1
intake victor SD
carb 950 950
how can you say a guy that has 56 more cubic inches is only going to make 30 more hp?
Re: Going to the Dyno in the AM...Guess the HP [Re: Mr.Yuck] #1213722
04/11/12 01:46 PM
04/11/12 01:46 PM
dogdays Offline
dogdays  Offline
Horsepower is limited by airflow when the engine gets big enough.
R.
Re: Going to the Dyno in the AM...Guess the HP [Re: dogdays] #1213723
04/11/12 01:52 PM
04/11/12 01:52 PM
Mooresville, NC
Mooresville, NC
610@5700 and climbing before rocker shaft problems ended the day.
Re: Going to the Dyno in the AM...Guess the HP [Re: A70Runner] #1213724
04/11/12 02:05 PM
04/11/12 02:05 PM
The Great White North
RAMM Online happy
RAMM  Online Happy
What was the nature of the problem? What was the torque looking like? J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
