Re: Going to the Dyno in the AM...Guess the HP
[Re: A70Runner]
#1213728
04/12/12 11:26 AM
04/12/12 11:26 AM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
What was the nature of the problem? What was the torque looking like? J.Rob
Seized the rockers to the shafts. tq [Email]598@4900[/Email]
ouch.
[Re: A70Runner]
#1213729
04/12/12 11:35 AM
04/12/12 11:35 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
how does that happen? lack of oil? I would think they'd make a bunch on noise before they siezed up...
[Re: JohnRR]
#1213732
04/12/12 12:09 PM
04/12/12 12:09 PM
Mr.Yuck
Brookeville, Md
In his case using rockers rated below the spring pressure.
Have you ever dynoed and engine or been present for one ? YOu aren't in the room with the engine , headers are usually open , there is a lot of noise .
just chassis dyno.
[Re: JohnRR]
#1213733
04/12/12 12:10 PM
04/12/12 12:10 PM
Posts: 971 Mooresville, NC
A70Runner
Mooresville, NC
Just talked to Comp. They said those rockers should be fine with my spring pressures.(or at least the new design ones.)
"People Think I'm Insane Because I Am Frowning All The Time" Black Sabbath
[Re: A70Runner]
#1213734
04/12/12 12:27 PM
04/12/12 12:27 PM
Posts: 75,062 U.S.S.A.
JohnRR
U.S.S.A.
I thought this came up before and that 500 was the number ?? Are yours considered the new design ?
Mods to your rocker oiling ???
Are they going to warranty them ?
[Re: A70Runner]
#1213735
04/12/12 06:04 PM
04/12/12 06:04 PM
Posts: 1,459 oklahoma
forphorty
oklahoma
Are these the Comp Pro Magnums? Seems like a few people were having those rockers bushed due to the steel-against- steel galling..... Never mind, i see you have started another post.
[Re: forphorty]
#1213736
04/12/12 06:34 PM
04/12/12 06:34 PM
Posts: 319 jonestown,pa
dmking
jonestown,pa
my 440 made 590ftlb at 4800 but stopped at 605 at 5800 cam at 104 solid. now at 108 and it picked up a strong >4 to .5 in the 1/4. i may put it in at 110 this season.....
[Re: dmking]
#1213737
07/22/12 04:12 PM
07/22/12 04:12 PM
A70Runner
Mooresville, NC
Ok finally got back to the dyno. Same combination execept Harlond Sharp rockers...... 657.5 hp @ 6100 638.6 tq @ 4800 on Sunoco 93!! Video of pull Tried a M1 with 1" spacer on it also.... ran 1 hp under the sd. The sd had a more straight curve to it. the m1 was very choppy. Sorry can't find the sheet right now for the M1 so no exact numbers. All in all made 16 pulls yesterday. Only "scare" was losing 50hp on the first run with the M1. found a piece of bowl gasket in the front jet. No harm no foul!! Very Happy!!!
[Re: A70Runner]
#1213738
07/22/12 05:02 PM
07/22/12 05:02 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Nice numbers.
Wondering what your .050 duration numbers are on the cam?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
