Re: 383cu stroker pistone ?
[Re: ppmracing]
#1158099
01/17/12 01:18 PM
01/17/12 01:18 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
dont think so ,,,,with 1,12 comp height and 4,280 bore ??????????
I have to go custome made ,,
That is your choice, the 4.150 stroke has fallen out of favor. The 1.320 compression height piston fits many differnt stroke lengths .
[Re: ppmracing]
#1158101
01/17/12 02:19 PM
01/17/12 02:19 PM
JohnRR
This is the same comp height when we ran with the 400 block,,,,and i dont think this has fallen out off favor ??? Same stroke,, same rod,, onley different bore size.
Maybe "fallen out of favor" was the wrong choice of words?
The 4.150 is not as "popular" now as it used to be, couple that with the 383 being the red headed step child of big block chryslers. It's in been the last few years that there are piston choices for the 383, but they are VERY LIMITED . Your best route is a semi custom Diamond piston.
