383cu stroker pistone ? #1158092
01/15/12 07:06 PM
01/15/12 07:06 PM
Sweden
ppmracing Offline OP
Sweden
What brand has piston in stock for a 383cu block, .030" , 4,150 stroke, 6,760 rods
Thanks.
Re: 383cu stroker pistone ? [Re: ppmracing] #1158093
01/15/12 08:27 PM
01/15/12 08:27 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I don't think anyone , 383 pistons for a stroker are few and far between , the standard piston CH for the 383 stroker is a 1.320 ch , it works with a 3.75 stroke , 3.91 stroke and 4.25 stroke.
I assume you already have the crank and rods ? If not then now is the time to change , I have a set of new diamond 1.320 .030 383 pistons that I'm going to sell ...
Re: 383cu stroker pistone ? [Re: ppmracing] #1158094
01/16/12 09:21 PM
01/16/12 09:21 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Well they sell the kits for 383 now so pistons are available.
Mancini's sells the 383 stroker kits so they have access to the pitons call wes!
Re: 383cu stroker pistone ? [Re: Dodgem] #1158095
01/16/12 09:31 PM
01/16/12 09:31 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
MuscleMotors offers 2 stroker kits too.
They dropped the 431 (3.75 crank) kit altogether but you could probably talk them into one.
http://www.musclemotorsracing.com/stroker-category.html
Re: 383cu stroker pistone ? [Re: Dean_Kuzluzski] #1158096
01/17/12 06:03 AM
01/17/12 06:03 AM
Sweden
Sweden
Cant see that this company have it for 4,15 crank and 6,760 rods ??
Wery strange to me , this is a good combo ,,
Re: 383cu stroker pistone ? [Re: ppmracing] #1158097
01/17/12 09:58 AM
01/17/12 09:58 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
440source has them
Re: 383cu stroker pistone ? [Re: Defbob] #1158098
01/17/12 12:02 PM
01/17/12 12:02 PM
Sweden
Sweden
dont think so ,,,,with 1,12 comp height and 4,280 bore ??????????
I have to go custome made ,,
Re: 383cu stroker pistone ? [Re: ppmracing] #1158099
01/17/12 01:18 PM
01/17/12 01:18 PM
JohnRR Offline
JohnRR  Offline
That is your choice, the 4.150 stroke has fallen out of favor. The 1.320 compression height piston fits many differnt stroke lengths .
Re: 383cu stroker pistone ? [Re: JohnRR] #1158100
01/17/12 01:46 PM
01/17/12 01:46 PM
Sweden
Sweden
This is the same comp height when we ran with the 400 block,,,,and i dont think this has fallen out off favor ??? Same stroke,, same rod,, onley different bore size.
Re: 383cu stroker pistone ? [Re: ppmracing] #1158101
01/17/12 02:19 PM
01/17/12 02:19 PM
JohnRR Offline
JohnRR  Offline
Maybe "fallen out of favor" was the wrong choice of words?
The 4.150 is not as "popular" now as it used to be, couple that with the 383 being the red headed step child of big block chryslers. It's in been the last few years that there are piston choices for the 383, but they are VERY LIMITED . Your best route is a semi custom Diamond piston.
Re: 383cu stroker pistone ? [Re: JohnRR] #1158102
01/17/12 04:06 PM
01/17/12 04:06 PM
dogdays Offline
dogdays  Offline
Don't let the name fool you, semi-custom isn't that much more $$ than shelf stock on these Diamonds or the like. I think it's less than $100 to move the pin.
R.
