Lifting car with subframe connectors? #1128225
12/05/11 06:07 PM
12/05/11 06:07 PM
MD
RTSE4ME Offline OP
RTSE4ME  Offline OP
MD
I installed a set a Hotchkis subframe connectors that were part of the TVS kit. Since installing them, I use them as the rear lift point on my mohawk lift. Noticed that one of the connectors is dented in pretty good and has a bulge on the side. Should I not be using the connectors as lift points?
Might of used my floor jack to lift the car once also.
Re: Lifting car with subframe connectors? [Re: RTSE4ME] #1128226
12/05/11 06:31 PM
12/05/11 06:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If they're that weak they arent doing much for the
chassis... yes I would quit lifting there
Re: Lifting car with subframe connectors? [Re: MR_P_BODY] #1128227
12/05/11 06:35 PM
12/05/11 06:35 PM
dogdays Offline
dogdays  Offline
No you shouldn't use them, too bad they didn't tell you that in the instructions.
Being a lifting point and increasing torsional rigidity are two different things so it ain't necessarily so that they weren't doing what they were supposed to.
R.
Of course, welding in a 2" X 3" X 1/4" wall steel tube would give you both, as well as a lot of road-hugging weight!
Re: Lifting car with subframe connectors? [Re: dogdays] #1128228
12/05/11 08:43 PM
12/05/11 08:43 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Id accept the extra few lbs for the added regidity. They sure firmed up my chassis flex in my 75 Duster racecar and I only used 1/8 wall..
I am truckless..
Re: Lifting car with subframe connectors? [Re: 340SHORTY] #1128229
12/06/11 12:23 PM
12/06/11 12:23 PM
MD
RTSE4ME Offline OP
RTSE4ME  Offline OP
MD
hmmm....I do have the US car tool ones sitting here. They look a bit thicker than the Hotchkis ones. I chose to install the Hotchkis connectors since they were really easy to install and I like that they tie into the front spring hanger. The US Car Tools ones would be a pain to fit since I have the brackets for a 6 way seat.
Re: Lifting car with subframe connectors? [Re: 340SHORTY] #1128230
12/06/11 12:31 PM
12/06/11 12:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats all I use to build connectors for customer cars
and you can use them as a jack point.... some of
the light weight connectors are in the .090 range
which is a bit thin to me
Re: Lifting car with subframe connectors? [Re: RTSE4ME] #1128231
12/06/11 12:32 PM
12/06/11 12:32 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I wouldn't jack up a car using any sub-frame connector, that's not what they are designed for.
Coming soon!!!!
Re: Lifting car with subframe connectors? [Re: Mr.Yuck] #1128232
12/06/11 04:12 PM
12/06/11 04:12 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
1/4" wall tubing?! Geez! I used 1/8" wall 2x3 its gotta be the strongest thing on the roller short of the brake pedal. I jack from there all the time.
Re: Lifting car with subframe connectors? [Re: radar] #1128233
12/06/11 04:33 PM
12/06/11 04:33 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
1/8" square tube here too. It doesn't go anywhere when I jack the car up.
Re: Lifting car with subframe connectors? [Re: dustergirl340] #1128234
12/06/11 04:43 PM
12/06/11 04:43 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
maybe it's an A-body thing. Not a chance I'd jack this pig up via the connectors.
Coming soon!!!!
Re: Lifting car with subframe connectors? [Re: Mr.Yuck] #1128235
12/06/11 06:37 PM
12/06/11 06:37 PM
dogdays Offline
dogdays  Offline
My reference to 1/4" wall tubing was an attempt to illustrate a ridiculous extreme. I don't think using metal a lot thicker than the existing "frame members" gets you anything.
Re: Lifting car with subframe connectors? [Re: Mr.Yuck] #1128236
12/06/11 07:42 PM
12/06/11 07:42 PM
Chicken coop
Chicken Little
Chicken Little
Chicken coop
Not just an A-body thing. My Duster is heavy too. That tubing is very strong. 1/8" square stock steel welded to each frame rail.
Re: Lifting car with subframe connectors? [Re: dogdays] #1128237
12/06/11 10:58 PM
12/06/11 10:58 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
For using them as a lifting point, a thinner wall wouldn't be as rigid.
I used thick wall rectangular 1.5x3 tubing and use it as a jack point all the time (67 Dart).
Re: Lifting car with subframe connectors? [Re: Exit1965] #1128238
12/06/11 11:38 PM
12/06/11 11:38 PM
WI
Dcuda69 Online content
Dcuda69  Online Content
WI
Re: Lifting car with subframe connectors? [Re: Dcuda69] #1128239
12/08/11 09:05 AM
12/08/11 09:05 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
If you go, you go all in for the connectors. Mine are 2x2 with 1/4" wall. They have been on there since 1993. Still one of the toughest part of the suspension. I never use it as a lift point. Always from the K-Member or the rear axle. Never used a jack stand on them either.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Lifting car with subframe connectors? [Re: Pyper70] #1128240
12/08/11 11:07 AM
12/08/11 11:07 AM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
I have 3/16 wall C material that the privious owner put on. I don't have any problems although I usually use the K member or rear end housing. They have been on the car for over twenty years.
Re: Lifting car with subframe connectors? [Re: RTSE4ME] #1128241
12/09/11 03:49 AM
12/09/11 03:49 AM
Sante Fe Springs, CA
Hotchkis Offline
Hotchkis  Offline
We created the subframe connectors to attach the front subframe to the hard points on the rear of the unibody, adding torsional rigidity. They’re really designed to prevent body flex and keep all four tire contact patches squarely on the ground so the suspension can do its job. Because there is a gap between the top of the SFC and the belly of the car, and the SFC is only attached at the front and rear, it does not make an ideal jack point. We would recommend sticking with factory hard points for jacking up the car.
