Re: Lifting car with subframe connectors?
[Re: 340SHORTY]
#1128230
12/06/11 12:31 PM
12/06/11 12:31 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Id accept the extra few lbs for the added regidity. They sure firmed up my chassis flex in my 75 Duster racecar and I only used 1/8 wall..
Thats all I use to build connectors for customer cars and you can use them as a jack point.... some of the light weight connectors are in the .090 range which is a bit thin to me
[Re: Mr.Yuck]
#1128236
12/06/11 07:42 PM
12/06/11 07:42 PM
Posts: 22,873 Chicken coop
dustergirl340
Chicken Little
Chicken Little
Chicken coop
maybe it's an A-body thing. Not a chance I'd jack this pig up via the connectors.
Not just an A-body thing. My Duster is heavy too. That tubing is very strong. 1/8" square stock steel welded to each frame rail.
[Re: dogdays]
#1128237
12/06/11 10:58 PM
12/06/11 10:58 PM
Posts: 3,378 Rancho Cordova, CA
Exit1965
Rancho Cordova, CA
My reference to 1/4" wall tubing was an attempt to illustrate a ridiculous extreme. I don't think using metal a lot thicker than the existing "frame members" gets you anything.
For using them as a lifting point, a thinner wall wouldn't be as rigid.
I used thick wall rectangular 1.5x3 tubing and use it as a jack point all the time (67 Dart).
[Re: Exit1965]
#1128238
12/06/11 11:38 PM
12/06/11 11:38 PM
Posts: 4,950 WI
Dcuda69
WI
[Re: Dcuda69]
#1128239
12/08/11 09:05 AM
12/08/11 09:05 AM
Posts: 5,906 Athens, Greece
Pyper70
Athens, Greece
If you go, you go all in for the connectors. Mine are 2x2 with 1/4" wall. They have been on there since 1993. Still one of the toughest part of the suspension. I never use it as a lift point. Always from the K-Member or the rear axle. Never used a jack stand on them either.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: RTSE4ME]
#1128241
12/09/11 03:49 AM
12/09/11 03:49 AM
Posts: 203 Sante Fe Springs, CA
Hotchkis
I installed a set a Hotchkis subframe connectors that were part of the TVS kit. Since installing them, I use them as the rear lift point on my mohawk lift. Noticed that one of the connectors is dented in pretty good and has a bulge on the side. Should I not be using the connectors as lift points? Might of used my floor jack to lift the car once also.
We created the subframe connectors to attach the front subframe to the hard points on the rear of the unibody, adding torsional rigidity. They’re really designed to prevent body flex and keep all four tire contact patches squarely on the ground so the suspension can do its job. Because there is a gap between the top of the SFC and the belly of the car, and the SFC is only attached at the front and rear, it does not make an ideal jack point. We would recommend sticking with factory hard points for jacking up the car.
