Re: what is the difference between a 68 and 69 RR hood?
[Re: mopar_leaner]
#1126144
12/02/11 03:06 PM
12/02/11 03:06 PM
Posts: 16,619 Almost Heaven
B_Body_Bob
Master of nothing
Master of nothing
Almost Heaven
Got the vents on it? 68s point up, 69s to the side.
Everybody makes fun of a hillbilly until they need something fixed
[Re: B_Body_Bob]
#1126145
12/02/11 03:11 PM
12/02/11 03:11 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
It's the other way around , also a 68 hood is closed off under the scoop bezels , a 69 there are opening so if the car is equipped wit han Air Grabber the air can pass thru to the ductwork.
68 scoops will bolt onto a 69 hood . to put 69 scoops on a 68 hood you have to at minimum drill a few holes to clear screw heads on the scoops themselves.
[Re: JohnRR]
#1126146
12/02/11 03:13 PM
12/02/11 03:13 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
![](/ubbthreads/images/graemlins/iagree.gif)
[Re: Part_Stalker]
#1126151
12/02/11 06:26 PM
12/02/11 06:26 PM
JohnRR
On a related subject, is there a difference between the scoops and vents for a 69 hood with or without the air grabber set up? I picked up some this summer in a deal and noticed there was a difference in the screen pattern. Not being fluent in RR's I never thought of that detail. I did make sure she got the set for her 68 though.
yes and no , the scoops are the same, no air grabber has a ribbed solid block off plate ... for it's pleasure ... air grabber has a screen .
[Re: JohnRR]
#1126152
12/02/11 07:48 PM
12/02/11 07:48 PM
Posts: 8,087 Elk Grove, Calif.
bigblock340power
Elk Grove, Calif.
Arn't all the '69 hood vent screens (ram air) painted red from the factory? I seam to remember this when I was into RR's.
[Re: Part_Stalker]
#1126155
12/02/11 08:20 PM
12/02/11 08:20 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Don't worry about stirring the pot! ![](/ubbthreads/images/graemlins/wink.gif) I just remember a "spirited" debate last time this came up and was looking forward to the sequel! ![](/ubbthreads/images/graemlins/biggrin.gif) Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: mopar_leaner]
#1126159
12/03/11 10:36 AM
12/03/11 10:36 AM
JohnRR
ok, I think I'm understanding it,a 68 with the side scoops out, can't see through, but a 69 you can. right?
Only if it has air grabber screens , otherwise it has a ribbed block off plate .
[Re: Part_Stalker]
#1126160
12/03/11 10:36 AM
12/03/11 10:36 AM
JohnRR
Didn't mean to stir up the pot. I will have to pull them off the shelf and look at them closer. If I remember right on one set the screens are diamond shape and the other set they are round. Maybe someone made a custom set.
I don't remember seeing different style air grabber screens , but you never know all depends on the vendor I suppose ?
