what is the difference between a 68 and 69 RR hood? #1126143
12/02/11 03:00 PM
12/02/11 03:00 PM
Hermiston Oregon
mopar_leaner Offline OP
Hermiston Oregon
we are trying to make sure we buy the right hood for a 68 Hemi Road Runner that is being restored. We now have two hoods to choose from, But don't know the difference between them.
thanks Moparts
( it takes a Mopar, to beat a Mopar!
email me at moparleaner@gmail.com )
Re: what is the difference between a 68 and 69 RR hood? [Re: mopar_leaner] #1126144
12/02/11 03:06 PM
12/02/11 03:06 PM
Almost Heaven
B_Body_Bob Offline
Master of nothing
B_Body_Bob  Offline
Master of nothing
Almost Heaven
Got the vents on it? 68s point up, 69s to the side.
Everybody makes fun of a hillbilly until they need something fixed
Re: what is the difference between a 68 and 69 RR hood? [Re: B_Body_Bob] #1126145
12/02/11 03:11 PM
12/02/11 03:11 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It's the other way around , also a 68 hood is closed off under the scoop bezels , a 69 there are opening so if the car is equipped wit han Air Grabber the air can pass thru to the ductwork.
68 scoops will bolt onto a 69 hood . to put 69 scoops on a 68 hood you have to at minimum drill a few holes to clear screw heads on the scoops themselves.
Re: what is the difference between a 68 and 69 RR hood? [Re: JohnRR] #1126146
12/02/11 03:13 PM
12/02/11 03:13 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Re: what is the difference between a 68 and 69 RR hood? [Re: MoparforLife] #1126147
12/02/11 04:32 PM
12/02/11 04:32 PM
The Scratch, WA
P
Part_Stalker Offline
P
The Scratch, WA
On a related subject, is there a difference between the scoops and vents for a 69 hood with or without the air grabber set up? I picked up some this summer in a deal and noticed there was a difference in the screen pattern. Not being fluent in RR's I never thought of that detail. I did make sure she got the set for her 68 though.
Re: what is the difference between a 68 and 69 RR hood? [Re: JohnRR] #1126148
12/02/11 05:11 PM
12/02/11 05:11 PM
Almost Heaven
B_Body_Bob Offline
Master of nothing
B_Body_Bob  Offline
Master of nothing
Almost Heaven
Oops my mistake.
Re: what is the difference between a 68 and 69 RR hood? [Re: B_Body_Bob] #1126149
12/02/11 05:43 PM
12/02/11 05:43 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
Here is a shot of a 68 hood showing that there is no cutout under the side facing scoops.
Re: what is the difference between a 68 and 69 RR hood? [Re: 68jim] #1126150
12/02/11 05:47 PM
12/02/11 05:47 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
With scoops and black out paint...
Re: what is the difference between a 68 and 69 RR hood? [Re: Part_Stalker] #1126151
12/02/11 06:26 PM
12/02/11 06:26 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
yes and no , the scoops are the same, no air grabber has a ribbed solid block off plate ... for it's pleasure ... air grabber has a screen .
Re: what is the difference between a 68 and 69 RR hood? [Re: JohnRR] #1126152
12/02/11 07:48 PM
12/02/11 07:48 PM
Elk Grove, Calif.
bigblock340power Offline
Elk Grove, Calif.
Arn't all the '69 hood vent screens (ram air) painted red from the factory? I seam to remember this when I was into RR's.
Re: what is the difference between a 68 and 69 RR hood? [Re: bigblock340power] #1126153
12/02/11 07:52 PM
12/02/11 07:52 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Ahhh; the red vs. black air grabber screen debate again......hang on, I need to grab a beer.
...OK, I'm ready now.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: what is the difference between a 68 and 69 RR hood? [Re: DPelletier] #1126154
12/02/11 08:15 PM
12/02/11 08:15 PM
The Scratch, WA
P
P
The Scratch, WA
Didn't mean to stir up the pot. I will have to pull them off the shelf and look at them closer. If I remember right on one set the screens are diamond shape and the other set they are round. Maybe someone made a custom set.
Re: what is the difference between a 68 and 69 RR hood? [Re: Part_Stalker] #1126155
12/02/11 08:20 PM
12/02/11 08:20 PM
DPelletier Offline
DPelletier  Offline
Don't worry about stirring the pot! I just remember a "spirited" debate last time this came up and was looking forward to the sequel!
Re: what is the difference between a 68 and 69 RR hood? [Re: DPelletier] #1126156
12/02/11 08:57 PM
12/02/11 08:57 PM
Hermiston Oregon
Hermiston Oregon
ok, I think I'm understanding it,a 68 with the side scoops out, can't see through, but a 69 you can.
right?
Re: what is the difference between a 68 and 69 RR hood? [Re: mopar_leaner] #1126157
12/02/11 10:07 PM
12/02/11 10:07 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Yup, '68 "scoops" are solid, basically an appearance item.
Many years ago, I bought an early (9/30/67 SPD) Roadrunner, and the guy had a '69 hood. We tried using the '69 hood on the car, but either the striker or secondary latch didn't line up with the '68 location. I used another '68 hood and it fit perfectly.
The Air Grabber screens on my '69 St. Louis RRs were a red-orange, and a square basketweave. I'd never seen them in black until the post already referred to.
Re: what is the difference between a 68 and 69 RR hood? [Re: mopar_leaner] #1126158
12/02/11 10:19 PM
12/02/11 10:19 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
I pulled this picture off the web - not mine - This would be the 69 style that has the open area under the scoops to mate up with the fresh air ducting. This is the reproduction hood that is currently available.
Re: what is the difference between a 68 and 69 RR hood? [Re: mopar_leaner] #1126159
12/03/11 10:36 AM
12/03/11 10:36 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
right?
Only if it has air grabber screens , otherwise it has a ribbed block off plate .
Re: what is the difference between a 68 and 69 RR hood? [Re: Part_Stalker] #1126160
12/03/11 10:36 AM
12/03/11 10:36 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I don't remember seeing different style air grabber screens , but you never know all depends on the vendor I suppose ?
Re: what is the difference between a 68 and 69 RR hood? [Re: JohnRR] #1126161
12/03/11 06:00 PM
12/03/11 06:00 PM
Hermiston Oregon
Hermiston Oregon
so 68s never had the air grabber option?
Re: what is the difference between a 68 and 69 RR hood? [Re: mopar_leaner] #1126162
12/03/11 07:02 PM
12/03/11 07:02 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No
