Re: what is the difference between a 68 and 69 RR hood?
[Re: mopar_leaner]
#1126144
12/02/11 03:06 PM
12/02/11 03:06 PM
Posts: 16,619 Almost Heaven
B_Body_Bob
Master of nothing
Master of nothing
Almost Heaven
Got the vents on it? 68s point up, 69s to the side.
Everybody makes fun of a hillbilly until they need something fixed
[Re: B_Body_Bob]
#1126145
12/02/11 03:11 PM
12/02/11 03:11 PM
Posts: 75,071 U.S.S.A.
JohnRR
U.S.S.A.
It's the other way around , also a 68 hood is closed off under the scoop bezels , a 69 there are opening so if the car is equipped wit han Air Grabber the air can pass thru to the ductwork.
68 scoops will bolt onto a 69 hood . to put 69 scoops on a 68 hood you have to at minimum drill a few holes to clear screw heads on the scoops themselves.
[Re: JohnRR]
#1126146
12/02/11 03:13 PM
12/02/11 03:13 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
[Re: Part_Stalker]
#1126151
12/02/11 06:26 PM
12/02/11 06:26 PM
JohnRR
U.S.S.A.
On a related subject, is there a difference between the scoops and vents for a 69 hood with or without the air grabber set up? I picked up some this summer in a deal and noticed there was a difference in the screen pattern. Not being fluent in RR's I never thought of that detail. I did make sure she got the set for her 68 though.
yes and no , the scoops are the same, no air grabber has a ribbed solid block off plate ... for it's pleasure ... air grabber has a screen .
[Re: JohnRR]
#1126152
12/02/11 07:48 PM
12/02/11 07:48 PM
Posts: 8,087 Elk Grove, Calif.
bigblock340power
Elk Grove, Calif.
Arn't all the '69 hood vent screens (ram air) painted red from the factory? I seam to remember this when I was into RR's.
[Re: Part_Stalker]
#1126155
12/02/11 08:20 PM
12/02/11 08:20 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Don't worry about stirring the pot! I just remember a "spirited" debate last time this came up and was looking forward to the sequel! Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: mopar_leaner]
#1126159
12/03/11 10:36 AM
12/03/11 10:36 AM
JohnRR
U.S.S.A.
ok, I think I'm understanding it,a 68 with the side scoops out, can't see through, but a 69 you can. right?
Only if it has air grabber screens , otherwise it has a ribbed block off plate .
[Re: Part_Stalker]
#1126160
12/03/11 10:36 AM
12/03/11 10:36 AM
JohnRR
U.S.S.A.
Didn't mean to stir up the pot. I will have to pull them off the shelf and look at them closer. If I remember right on one set the screens are diamond shape and the other set they are round. Maybe someone made a custom set.
I don't remember seeing different style air grabber screens , but you never know all depends on the vendor I suppose ?
[Re: mopar_leaner]
#1126162
12/03/11 07:02 PM
12/03/11 07:02 PM
JohnRR
U.S.S.A.
so 68s never had the air grabber option?
No
