Help me choose a killer cam for my 440
#1115682
11/17/11 06:23 PM
11/17/11 06:23 PM
Posts: 9,670 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
Here is the rundown of my combo:
-440 STOCK STROKE -forged pistons -10,5:1 compression -440 source stealth heads, port matched bowl blended. -Performer RPM intake port matched -440 source adjustable rockers 1,6 ratio -I have a 750 DP holley carb, although I think it might be too small, or is it OK? -I plan on using 70.71 HP exhaust manifolds -full 2,5" exhaust
4,10 gears 4 speed transmission
this is going in a 71 cuda in full street trim.
I was thinking it might be the ticket to use a solid flat tappet cam in here? No, I dont want to spend more on a roller.
Re: Help me choose a killer cam for my 440
[Re: domingo]
#1115687
11/17/11 09:12 PM
11/17/11 09:12 PM
Posts: 5,620 long island NY
Ari440
long island NY
my 440-6 has a 557 /255 with 1.6 ratio rockers
1.39 9.85 - 137 mph
[Re: domingo]
#1115690
11/17/11 10:19 PM
11/17/11 10:19 PM
Posts: 4,324 Prospect, PA
BSB67
Prospect, PA
Less is more. .528 if you want something off the shelf.
[Re: BSB67]
#1115694
11/18/11 01:04 AM
11/18/11 01:04 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
with the .528. Ron
[Re: domingo]
#1115695
11/18/11 01:41 AM
11/18/11 01:41 AM
Posts: 1,093 Long Beach, CA
Mike Swann
Long Beach, CA
Get one from indy, it will kill your valve springs.
8.30's @3400 lbs
[Re: domingo]
#1115696
11/18/11 03:28 AM
11/18/11 03:28 AM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
242@ .050 on a 110lca. Lift will be about .560 gross and only about .014 lash.
Brian Hafliger
[Re: Lee446]
#1115697
11/18/11 05:50 AM
11/18/11 05:50 AM
Posts: 14 Europe
BB 70 Challenger
Europe
M.P. 528 solid.
![](/ubbthreads/images/graemlins/iagree.gif) With cast iron stock exhaust manifolds, it is said to work very well. Iīve heard that so many times. So thatīs the cam I would pick.
[Re: metcoll]
#1115700
11/18/11 01:51 PM
11/18/11 01:51 PM
domingo
EL Master
EL Master
Lima, Peru
I had already bought this cam for this engine: http://www.summitracing.com/parts/CCA-CL21-225-4/But I started this thread because I thought it was a bit small and I was leaving power on the table. This is a street car but that will see some strip action. It is a 71 cuda with a 4 speed and 4,10 gears like I said. How much power do you think Id be making with the above cam, and how much more do you think I could gain by going to a solid like the MP .528" or the Scott Brown?
[Re: domingo]
#1115701
11/18/11 02:08 PM
11/18/11 02:08 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
remeber the 528 is going to be about 500 once you adjust for lash. I ran both in a 440-6 (528 and the 548) the 548 felt much stronger. The one you have now seems like a good cam. Just run it
