Re: What type of 'Sure-grip' is this??
[Re: 76Beeper]
#1093921
10/14/11 02:23 PM
10/14/11 02:23 PM
Posts: 43,317 Bend,OR USA
Cab_Burge
Taht is the dana Corp. clutch type posi with a set of Richmond gears added onto it ![](/ubbthreads/images/graemlins/shruggy.gif) BTW, that posi is rebuildable, DR DIFF,Cass, ahs all the parts to rebuild it, if and when it is needed ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) You have to take them apart to get to and see the clutches and drive paltes, side gears and so on ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: MLR426]
#1093923
10/14/11 06:28 PM
10/14/11 06:28 PM
Posts: 356 Stoney Creek, Ontario, Canada
76Beeper
Many Thanks for the info my Mopar brothers! ![](/ubbthreads/images/graemlins/thumbs.gif) I was told some time ago that you couldn't really see the clutches on that type of Sure-Grip unit & there's a difference on the way the unit is bolted to the ring gear support - on a cone style the bolts come in from the ring gear side - on a clutch style they come in the opposite direction. Thanks again!
