What type of 'Sure-grip' is this?? #1093916
10/13/11 09:12 PM
10/13/11 09:12 PM
Stoney Creek, Ontario, Canada
76Beeper Offline OP
76Beeper  Offline OP
Guy's here's a picture of a 742 case I just pulled from my 71 Satellite.
The previous owner said it has 4:10's with a sure grip but have alook.
I can't see any springs, clutches or cones.....and it sure isn't a one wheelie peelie.
Any ideas?
Re: What type of 'Sure-grip' is this?? [Re: 76Beeper] #1093917
10/13/11 09:13 PM
10/13/11 09:13 PM
Kirkland, Washington
Pacnorthcuda Offline
Clutch type! THe good one!
Re: What type of 'Sure-grip' is this?? [Re: Pacnorthcuda] #1093918
10/13/11 09:41 PM
10/13/11 09:41 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: What type of 'Sure-grip' is this?? [Re: MoparforLife] #1093919
10/14/11 02:25 AM
10/14/11 02:25 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
with aftermarket gears
I am truckless..
Re: What type of 'Sure-grip' is this?? [Re: 340SHORTY] #1093920
10/14/11 12:59 PM
10/14/11 12:59 PM
dogdays Offline
dogdays  Offline
SCORE!!! PowrLock
R.
Re: What type of 'Sure-grip' is this?? [Re: 76Beeper] #1093921
10/14/11 02:23 PM
10/14/11 02:23 PM
Taht is the dana Corp. clutch type posi with a set of Richmond gears added onto it BTW, that posi is rebuildable, DR DIFF,Cass, ahs all the parts to rebuild it, if and when it is needed You have to take them apart to get to and see the clutches and drive paltes, side gears and so on
Re: What type of 'Sure-grip' is this?? [Re: Cab_Burge] #1093922
10/14/11 02:42 PM
10/14/11 02:42 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
11/30/67 dated clutch type and a good one
logan426
Re: What type of 'Sure-grip' is this?? [Re: MLR426] #1093923
10/14/11 06:28 PM
10/14/11 06:28 PM
76Beeper Offline OP
76Beeper  Offline OP
Many Thanks for the info my Mopar brothers!
I was told some time ago that you couldn't really see the clutches on that type of Sure-Grip unit & there's a difference on the way the unit is bolted to the ring gear support - on a cone style the bolts come in from the ring gear side - on a clutch style they come in the opposite direction.
Thanks again!
