Re: What type of 'Sure-grip' is this??
[Re: 76Beeper]
#1093921
10/14/11 02:23 PM
10/14/11 02:23 PM
Posts: 43,218 Bend,OR USA
Cab_Burge
Taht is the dana Corp. clutch type posi with a set of Richmond gears added onto it BTW, that posi is rebuildable, DR DIFF,Cass, ahs all the parts to rebuild it, if and when it is needed You have to take them apart to get to and see the clutches and drive paltes, side gears and so on
[Re: MLR426]
#1093923
10/14/11 06:28 PM
10/14/11 06:28 PM
Posts: 354 Stoney Creek, Ontario, Canada
76Beeper
Many Thanks for the info my Mopar brothers! I was told some time ago that you couldn't really see the clutches on that type of Sure-Grip unit & there's a difference on the way the unit is bolted to the ring gear support - on a cone style the bolts come in from the ring gear side - on a clutch style they come in the opposite direction. Thanks again!
