You can tell if the rockers are drilled for Chrysler oiling if the oil hole in the rocker arm is in the bottom thread of the adjuster screw hole.
I have 4 sets of aftermarket rockers. All of them have the oil hole well below the bottom thread of the adjuster hole. Are there any aftermarket rockers that are set up for "Chrysler" oiling?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
