Major enough that your toasting pushrods. Try getting ones that fit and get oiled.Quote:
Sorry, but I cant see .050 being the differnce between life and death..... See my previous threads about another motor I have that had pushrod lengths all over the place...None of it helped....But, I never had them set exactly as Dwayne told me too either. As it was set up, the pushrod length was well within the parameters most people regurgitate....Thousands of motors are probably running with 1.5 threads out of the rocker...and not having a problem...But, for me it hasnt/doesnt work that east...
I do believe (and hope)the difference will be in the rockers. We shall see...
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
