Quote: Had the same problem sometime ago. Staggered the seals and never had a problem again. Chuck
Also,,I silicone behind/back of the seal and put a little on the ends where they meet together in the housings. The oil you are seeing may be going BEHIND the seal and the seal to crank area not be the actual source of the leak.
If you like drag racing, support your local track.
