040 440, 10.5 comp, ported 452s (no flow numbers, but probably 250-260@ .600), M1 intake, 950HP,2 inch Hookers, 259/.550 Comp TL solid, 5k flash converter, 4.30 gear. 3800lbs, 11.3X's. With a 4k vert went 11.49.
Very nice combo on the street and runs find on pump fuel!!
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
