I find this confusing because there are 8 different methods/opinions on the subject .
SO--lets try a new approach. Im going to post my measurements and lets see if everyone comes up with the same number in the end .
Here we go:
d-shaft at rear angle 86 degrees (4 ? ) DOWN measured on bottom of shaft. D shaft is pointed down at rear.
pinion flange 81 degrees (9 ? ) DOWN vertically measured . pinion is pointing down .
trans seal - measured vertically 88 degrees (2?) UP .
pinion yoke (u joint cap) 5 degrees DOWN
so ... what is my pinion angle ?
trans seal 88, so it's 2 degrees up. for 0 pinion angle, the pinion yoke measurement would need to be 2 degrees down.
all the other measurements are given are irrelevant. since your pinion is rotated another 3 degrees nose down from 0, you're at 3 degrees nose down.
1976 Spinnaker White Plymouth Duster, /6 A833OD 1986 Silver/Twilight Blue Chrysler 5th Ave HotRod **SOLD!*** 2011 Toxic Orange Dodge Charger R/T 2017 Grand Cherokee Overland 2014 Jeep Cherokee Latitude (holy crap, my daughter is driving)
