Quote: Found an oversight in my parts selection this afternoon. 5.2 and 5.9 magnums use the same oil pan, not like 318 vs 360 LA. When I first filled it with oil I had a leak and chalked it up to me screwing up the gasket install. After the second one this afternoon leaked I looked it up online and got conflicting stories. MP tech line confirmed that I need a 360 car pan instead of the 318 pan for the 5.2 or 5.9, and they said the one piece rubber gasket should work. Minor issue, but annoying!
the one piece does not work. I know. unless you adjust the pan, it will leave a gap at the front and back of the motor. you need to use the LA gasket set.
