ok guys antifreeze will change over time and become corrisive, cyle of heat /cold and age
thats why you are supposed to change youre fluid every 2 years or when ever ,
water does conduct elec ,
if you have 12 volts running thru you radiator ,,
FIX YOURE PROBLEM,
COLLANT DOESNT GENERATE ELECTRICITY!!
alluminum radiators , alluminim heads require , attention as to corosive types of antifreeze, and proper ph balance
as with desil motors same deal
it would be very usefull to use distilled water as it has little to no impuritys to break the antifreeze down you are using quicker,
