Call Best Machine to see if they still have their solid roller lifters available. They were sourcing lifters that work in a stock block with the internal pressure feed.
These lifters also a the oiling hole drilled so they do not feed from directly from the oil gallery. This helps greatly to limit the oil flow to the pushrods and they have roller oiling.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
