on my comp xr286r I ran harland 1.7s which gave me .660 lift range! I ran the melling HV oil pump and the comp solid body lifters - 3/8th pickup! Indy EZ MW heads that oil'd through #4! pause the vid at 11 seconds and you can see my oil pressure is at 76lbs also! Hope any of this helps you with your route to go.
Car ran pretty good out on the street and track with such a small cam and big lazy ports and a 1050 dominator!
