Re: How bad will a glide kill my 500 CI @ 3425 lbs.
[Re: JERICOGTX]
#863250
11/26/10 10:49 PM
11/26/10 10:49 PM
Posts: 2,584 sycamore,ohio
BobsProFab
sycamore,ohio
If the rules allow the Liberty, and you have to start from scratch, I wouldn't think of anything but the Liberty, and take the 50lb added weight. Lets face it the Liberty is a purpose built transmission, and can be had with just about ANY gear ratio combo you can think of. Clutch can be set up for track conditions, and NOTHING is cooler then dropping the clutch and rowing the gears.
there is only the 50 lbs. if you run them clutchless there used to be a 100 lb penalty for the 5 speed liberty's, but they did change that since Liberty sponsors the class.
