Ok , im starting to look at running a glide behind my 500 inch motor to try and kill it some off the line running TT5's and not completely relie on a 7531 box
the biggest problem i see is i need to weigh in @ 3425 to make weight
i know it will kill it on the shift recovery
looking for any of you guys that switch to a glide @ similar weight to share your results.
