You said they're bushed. Is there a hole in the bushing and does it line up with a hole in the rocker arm? Is there a passage in the arm and is it clear? Seems odd that you would get 2 sets of rockers with the same flaw unless they are for oil thru push rod only.
Kevin
I said bushed, but was meaning bushed as opposed to a full roller set up, such as HS. They do not have a press in bushing. All the passage ways are clear and free.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
