It doesnt ride lower. Half and 3/4 tons use a coil that is 11" tall when on the ground and yours are 13.13" when on the ground installed on the truck so its actually only .13" taller do to the pocket. Free hieght for the stock 94 coils are 12.92dr and 12.63ps and thats not loaded. so take 3" out of than and its 9" for both plus 2"for the coil totaling 5" of drop. Did you put the springs side by side?
