If you have the 3 wire switch on trans, then the original column shifter is not involved in the starting. What year?
How could it NOT be involved, it has to be
It's not, all the wiring goes thru the neutral safety switch. To bypass it ground the terminal on the starter relay and it's out of the circuit. Got to be careful as the car will start in gear.
