Its a 71 Swinger, it does have the 3 wires, it doesn't do it all the time, but IF i lower the original column where the shifter arm was (or it falls on its own) it won't start in any gear, if i shuv it back in place it'll turn over like it should (in "N" & "P"), but "sometimes" it acts up & won't turn-over, so i'm thinking its in the column, there must be a wire or something that column.
I'll double check the position of the arm on the trans with my floor shifter & make sure its adj.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
