Quote: If you do try to modify a stock one be sure to remove ALL the electrical components off the thing before try to solder a larger fuel pickup tube to the plate...DAMHIK...
Sixpack I will follow your advise. Any idea what the ohms are supposed to be?
Sorry, no...I just remember ruining the electrical components on mine when I tried to solder a 1/2" pickup into mine. I got to believe they swedge or solder the tube to the plate first and then add the electrical stuff. Those things aren't really built to be disassembled so take your time.
