Those metering plates are expensive
You can drill/tap them to use regular screw in jets . there's just enough material to get enough threads to hold it. I eyeballed it to find the passages & did it but it was 20 yrs ago & I didn't take pics but when you get in there you'll be able to see where. worked good but did have to play w the jets some.
