i think if you were to be grabbing the cage with that puller, you'd detroy the bearing by twisting the cage in to a pretzel.
you need to get the fingers of the puller onto the inner race or else
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
