Can you post a pic of the vinyl top in the side window area? When my top was installed, the guy wrapped the vinyl around and covered up the drip rail mounting holes. The top shouldn't wrap around that far right? Shouldn't it be trimmed off right after it wraps around the drip rail? The way it is now, my drip rail seal and the trim would be installed ontop of the vinyl. That can't be right.
