Most of the sheet metal was in sort of good shape. The outer wheel housings, the trunk extensions and the right rear quarters needed replacing due to rust. The back valence was damaged in the blizzard of 82 when it got yanked from a 5 foot drift. A fellow firefighter Brett Marine fitted the pieces for me. I was going to patch the right quarter but Goodmark announced a full quarter so that was the route I took. It took care of a rust spot under the rear window as well as the other rust damage behind the wheel.
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
